Go to Post But here's the beautiful thing about FIRST: you are supposed to make mistakes. - RunawayEngineer [more]
Unread 04-06-2007, 07:34
Re: Why Not Use ISM band?
Everyone,
Your radio links are monitored during competition and if there is a radio issue you will be notified. Most often a lead inspector will carry the message and help you look for problems. I had far less radio issues this year then in the past once the new code was loaded into the radios. Most radio issues come from kinked or otherwise abused cabling, mounting of the radio deep inside the robot base or next to a motor, or battery issues.
Why you should use Gmail Nathan Chit-Chat 5 22-02-2007 00:20
Ethics 101: To re-use or not to re-use? aaeamdar General Forum 87 07-12-2006 19:10
Why would you use FIRSTwiki? Max Lobovsky FIRSTwiki 4 18-07-2004 23:59
Why (not) flash? tchescow Website Design/Showcase 10 04-01-2004 16:29
Non - GP-ism at SVR CaseyG668 Regional Competitions 18 27-04-2003 15:08
