Go to Post If there was no internet then somebody in FIRST would probably invent it. - Koko Ed [more]
Unread 01-06-2007, 15:49
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Re: No Sound
Mouse may just be wear and tear (espicially the tap pad). As for sound a setting may have been changed in Windows or the BIOS preventing the sound from working. You could always go to the Lapto Manufatures website and re-downloading the Audio Driver for your laptop and the mouse / tap pad as well. If that works then its all fine and dandy. If not prep your laptop for formatiing (get copies of all your documents etc...). I have not had much luck with Restoring the system to the last known good date only b/c not many people know about it nor do they know how to work it properly. But it's always a shot. Restore the system to its last known good date. If that don't work, use the master restore CD / DVD (for the much newer models) to restore the system back to when it was first shipped to you. (YOU WILL LOSE YOUR DATA IF YOU DON'T BACK IT UP ESPICIALLY WITH THE LAST OPTION!!!!!!!). CMOS Batteries should be replaced every 3 - 5 years but don't generally go bad ever. CMOS Batteries help the BIOS remember all the information & settings. If the battery should go all it will do is forget Time / Date and User Settings and should not have immediate effects on system operation except the before mentioned items. (User Settings in BIOS).
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 01-06-2007, 22:48
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Re: No Sound
Hm... well, my computer is practically brand new. It was a replacement for my other laptop that the keyboard went bad on. They sent me a new computer and let me keep the old one, so I got a brand new computer for $80.
But I digress... the computer won't let me copy anything or run anything in Safe Mode. I haven't messed with it for a while because it stormed terribly here (tornadoes, hail, lightning, etc).
I've run the restore to previous time, but that too didn't work.
Al, I've had the computer since January, I think. It does run a lot, but I turn it off when I'm done using it 98% of the time. No weird sounds. How do I get the CMOS? How do I use a disk with DOS commands?
The mouse and sound card aren't really an issue right now. I think I know that the sound card is a driver issue. But the mouse can't be worn out, it just won't let the tap option say unselected.
Thanks for the help, again, everyone.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 02-06-2007, 13:15
Re: No Sound
Budda,
CMOS or the setup for your computer can be accessed by pressing one of the Function keys while the computer is booting up. Usually it is F1 but on some computers it is the DEL key. It should tell you during the boot up screen which to use. If your computer has a floppy drive and if another computer has a floppy drive you can format a system disk that allows you to at least see directories on the drive. You will need a DOS primer to know how to step through the commands. usually by typing c: you can get to the root directory on the C drive. Then type dir/p and you will get a directory listing one page at a time. Hit any key to advance and you will see if all is still on the drive. If there is nothing on the drive then you may have to format C: and rebuild. I think you may have other problems though.
If you suspect a sound card problem, you might disable it in the CMOS setup. Save the settings and then continue to boot.
There are some really nasty viruses out there that wipe the boot sector of the drive. That is where the turn on info for your computer resides. It might be recoverable but you will need a good virus program to do that.
Unread 02-06-2007, 16:12
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: No Sound
If you have a windows XP install disk you can use Recovery Console to re-configure your computer.
If you insert the disk and boot your computer, before the install starts it will ask if you want to run the install, or run recovery console. If you run recovery console, you will get a DOS-like prompt. You will need the know the administrator password on your computer, because you will log-on to your existing winXP install. You will be running winXP off the CD, without a GUI, but logged into your existing winXP install.
What that means is you will have full access to any configuration setting for Windows. I'm hoping there is someone here who is more familiar with Recovery Console who can give you some ideas. I have only ever used it to perform a system restore when I couldn't even boot into safe-mode, and I was following an online guide.
Recovery console is a very powerful tool. It has the power to destroy your Windows install, and corrupt your hard drive. BE VERY CAREFUL WHAT YOU DO!
Eric Haskins KC9JVH
Unread 03-06-2007, 15:50
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Re: No Sound
Thank you all for your help. I fixed the problem... seems that my computer won't start up if my digital camera memory card is in the slot. The sound problem has been fixed, too. Thanks again.
Do The Tyler!
Unread 04-06-2007, 07:56
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: No Sound
Please back up everything. Make your restore disc(s) and be ready if your hard drive goes south this afternoon. That way, you'll be ready if it does. The reason I say this is that it is odd that a memory card would bother the boot process at all.
Please try the following only after you've backed it up first:
You might try running a check disk--open the Run window (either by pressing R with the Windows key held, or if you don't have a Windows key, press Start, Run) and type:
chkdsk c: /r
and press OK. A DOS-style window will open; it should state that it cannot lock the drive. Type Y and press enter; this will let the scan run when the system reboots. Restart it; the scanner will do a detailed scan. If you see a bunch of errors, you may have seen a hard drive failure.
JBot
Aren't signatures a bit outdated?
Unread 04-06-2007, 18:07
mtaman02's Avatar
Re: No Sound
chkdsk c: /r
JBot
I hate to say this but any type of Flash or USB Ext. Drive will cause the system not to boot up. During the POST the system looks and finds all drives and see's which one it can try and boot from. It finds a USB Ext Drive or Flash Drive it will try and boot from it. The only way to change it from looking at them is to change the Startup Process and make sure that the Removeable Disk is the last thing that the BIOS will try and boot from and that CD-ROM, Floppy and HDD are in that order.
Volunteer Resume:
Unread 04-06-2007, 21:52
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Re: No Sound
I realize that the computer will try to boot to a USB drive; I have done this myself. However, this will only give a "No OS" or "Error loading OS" or black-screen-with-flashing-gray-underscore error, and will never boot Windows (OK, if you configured your flash drive's MBR to point to the hard drive, it will work, but I'm assuming that's not what's going on). That system, if trying to boot from an SD card, would not boot at all!
Good point though. If it was me, I would be preparing myself for it to fail. That way, there are no surprises of the bad kind. That's just sound advice anyhow.
JBot
Unread 04-06-2007, 22:31
Re: No Sound
Guys,
It seems to me that there is a known problem with camera memory cards and startup on Windows computers. It is not related to a boot sequence, but as I remember had something to do with a hardware interupt used during the boot sequence and the interference of the memory card. This causes problems on both internal and external card readers. I know it was an issue with our external card reader last year.
Unread 05-06-2007, 00:04
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Re: No Sound
Yeah, this was an issue with an empty SD Memory Card Adapter/Extender used to allow my SD card to fit in the slot. I didn't even realize it was in there. I had my dad take a look at it, which is always a last resort, and he called back saying that I was an idiot. No new news there. Anyhow, it's back to working perfectly and I see no reason it could fail now. The mouse thing still doesn't work, but I've given up on it. As a precaution, everything is now backed up.
Do The Tyler!
Unread 05-06-2007, 07:34
Re: No Sound
No biggy, now you know how to use the Notke rule. When something stops working go where the last person was. Now on to the mouse...do you have both an internal and external mouse connected? They usually conflict with each other. There may be some software that resets the mouse to a specific operation when you open it.
Unread 05-06-2007, 12:10
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Re: No Sound
No, the mouse is just the internal, tap pad. It's a Synaptics and there are options to change the settings under the mouse part of the control panel. However; when I do that, it usually reverts back to its previous state within 30 minutes or so.
Do The Tyler!
Unread 05-06-2007, 14:16
Re: No Sound
I have a Synaptics pad on my laptop and don't have a problem. I really like the scroll features on the side and bottom. You might want to peruse the Synaptics website for known issues or driver updates. Same goes for Microsoft. You might not be the only one having this issue.
Sound Sensor hello1990ab Programming 2 31-07-2006 09:37
sound? kyo11103 3D Animation and Competition 0 17-01-2003 17:57
Sound Systems Andrew Rudolph Chit-Chat 25 09-11-2002 00:05
Robot Sound archiver 2001 0 24-06-2002 00:06
The Importance of Sound ComBBAT_Albrot 3D Animation and Competition 8 09-03-2002 20:33
