Go to Post "Who needs finesse when you have air pressure?!" - neelpatel1710 [more]
Unread 02-06-2007, 23:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: 254/968 Gearbox - Destructive Testing Results
Interesing points about the reduced costs with very large production runs.
Many teams rely on others to shoulder the "up front" cost of buying/leasing CNC equipment, and end up buying parts that available off the shelf ....it's neat that you had the opportunity to design and make these transmissions!
Unread 04-06-2007, 10:47
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Any chance you'll do endurance (constant fluctuations in fatigue) testing with this transmission? Granted these things are built for (at most) 3 competitions and a bit of practice (about 120 minutes of run time if you make the finals at competitions) but what would happen if you tried to put the robot under its stresses for say, twice that amount of time in a competition-style environment?
My Material's Science intro class went over a bit of sheer stress analysis but the details escape me at the moment. Is there a way to get a product lifetime estimate from the tests done already?
Excellent opportunity you have to be able to do such a disciplined and detailed analysis.
GitHub
Unread 04-06-2007, 15:14
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Funny you ask. We did do long term accelerated wear and fatigue testing.
We built a total of 16 gearboxes. 4 of them went on competition robots. 254's comp bot saw ~8 hours total run time including practice at 4 events. 968's comp bot saw only ~4 hours run time including practice at 2 events.
However, there were another 4 gearboxes built and used on two practice robots which each saw ~100 hours of driving. After these 100 hours of aggressive use, we saw little to no difference between the practice robot gearboxes and the competition gearboxes with less than 10% of the runtime the practice ones saw. It was determined that the anodize wears initially after 2 or so hours of use and remains at that worn, broken in point for the remaining time.
In addition to those 8, we used 2 more gearboxes on an accelerated wear test platform. We mounted the gearboxes onto a mock side rail and programmed a continuous loop program to cycle the motors and actuate the shifting cylinder: full forward, shift, full reverse, shift, for another 100 hours under load.
Here is a picture of that test platform after the 100 hours of testing. You can see the anodize wear, but after measurement, the involute tooth profile is intact. We also disassembled the gearboxes and checked for any fatigue issues and further damage or wear... while we didn’t have the ability to do a thorough lab test, our brief visual inspection showed no damage or signs for concern.
Also, here is a video showing the test platform with a wheel mounted for later use as a demonstration unit. As shown in the video and pictures, there is no load on the output shaft. This video is strictly to show the cycling procedure used. We may bring this to IRI if people want to see it?
http://sivart.org/misc/Demo%20Gearbox.avi
Lastly, here are the components removed from the test platform after ~100 hours of continuous use. Some wear is noticible, other portions are just dirty from the anodize wear.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 04-06-2007, 16:02
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
These are amazing results. Even better, Travis has done a great job explaining this testing and failure modes.
It is one thing to be a great designer, it is another thing to be able to explain what you did, how things work, and why things happen.
Personally, I appreicate this work. Needless to say, FIRST will see better designs from many people because of this effort. This design has indeed "raised the bar" in FIRST.
Most respectfully,
Andy Baker
Unread 05-06-2007, 09:58
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Very nice, very strong, looks like a great piece of equipment.
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 05-06-2007, 13:50
AdamHeard's Avatar
Lead Mentor
Travis,
Great work guys. I have been fascinated by these transmissions ever since the first pic shown and have spent a good amount of time at LA, SD and champs admiring them. The amount of work put in is really shown in every part and detail. Also, the fact that you are going to such great lengths to publish your results (I know you did the test anyway for the senior project) is much appreciated. I am already inspired and thinking of what I can do for my Senior Project at San Luis Obispo and I haven't even finished my senior year of high school yet.
Originally Posted by Andy Baker View Post
Personally, I appreciate this work. Needless to say, FIRST will see better designs from many people because of this effort. This design has indeed "raised the bar" in FIRST.
Most respectfully,
Andy Baker
Sorry, couldn't resist, but does AndyMark have any improvements planned to the your shifters?
Unread 05-06-2007, 14:06
Yes, there will be a new version of our shifter available this fall, but I don't want to take the focus off of what 968 and 254 have done here. There will be enough information about that later.
I am looking forward to IRI for many reasons, and one of them is to talk with Travis and get a tour of this gearbox.
Andy
Unread 15-06-2007, 17:27
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Wow! A very impressive effort both in the design and the quality of testing. Really nice work, guys!
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 19-06-2007, 14:58
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
FRC Video Review - Change is Coming
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
I checked these out in Atlanta and they're the real deal. Quite possibly the most amazing transmissions I've seen to date in terms of simplicity, quality, and resilience. The coolest part is just picking it up, like a mechanical feather or something...
I'm anxious to see what other ideas come as a result from these gearboxes. Great job guys.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
254/968 Gearbox Assembly Time Study/Analysis Travis Covington Technical Discussion 8 08-05-2007 13:40
pic: 254/968 Transmission Travis Covington Extra Discussion 42 24-04-2007 16:25
pic: 968/254 Transmission Joe Ross Extra Discussion 4 03-04-2007 00:25
pic: 254 and 968 on Newton alphaone Extra Discussion 10 17-02-2007 08:28
pic: Anodized Parts 254/968... ejSabathia Extra Discussion 12 02-02-2007 15:31
