Go to Post When more STEM teams exist outside schools than in them, that will be one indication that a true cultural change has occurred. - gblake [more]
Unread 06-06-2007, 22:34
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
DIY open exhaust
Downshifted a little too hard coming out of a corner. Engine kicked and ripped the cat off the turbo.
http://img.photobucket.com/albums/v7...atturbo002.jpg
http://img.photobucket.com/albums/v7...atturbo001.jpg
I'm bored, figured this would amuse some people
http://www.mikesorrenti.com/
Unread 06-06-2007, 22:43
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
Re: DIY open exhaust
Same thing happened to the truck I drive for work. The cat blew right off onto the street. My boss still hasn't had it put back in, so there's just a straight pipe to the muffler right now.
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 06-06-2007, 22:52
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Same thing happened to me, except it rusted right off. Had to buck up $200 for a new muffler. '91 Chevy S10... not even worth $200. Paid $500.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 06-06-2007, 22:57
Mike's Avatar
AKA: Mike Sorrenti
Yeah, it seems to be a pretty common problem apparently.
For right now I'm probably just gonna pry it back in and have my friend tack weld it. Eventually I'll throw a cat-delete racing downpipe (only $165) on it, when I have time to even try and get those flange nuts off. PB blaster is gonna be my friend.
Fits 1997 - 2001 Audi A4/Vw Passat with K03, K04, or ATP Elminiator Series Turbos 3" racing downpipe deletes restrictive cat immediately after the turbo on the longitudinally mounted 1.8T. There is no welding or cutting necessary. The downpipe has a large 3" opening to take full advantage of the turbo flow and has provisions for the factory oxygen sensors. Typical gain is 200 to 400 rpm sooner spoolup and 40 ft/lb of wheel torque. HP gain is 10-15 on stock and K04 turbo and 30-40 on GT28RS or larger turbo. Our favorite when used with stock exhaust for ultra quite stealth sound. This part is for offroad use only.
http://www.atpturbo.com/Merchant2/me...Code=AUDIVW-DP
Pneumatics - what do we do with exhaust air? devaaki Pneumatics 13 10-02-2007 11:30
DIY water cooling Morenoh149 Chit-Chat 2 28-02-2006 23:44
DIY Active Noise Cancellation phrontist Technical Discussion 20 28-08-2004 07:45
switch lever exhaust Jeff Rodriguez Pneumatics 8 07-12-2003 07:14
Robot Rivals on the DIY network sanddrag Televised Robotics 1 07-11-2003 22:49
