Re: Radio Probs
To add to what prograid said, you shouldn't ever assume the initialization state of any variables in your program. This can lead to very bad problems, especially since a value of 0, a common initialization value, does not halt the motor! If you do not set the PWM values to idle you can have some very weird and dangerous results. |
Re: Radio Probs
Even if you are doing other things in autonomous it is a bad idea not to set the PWMs to 127. |
Re: Radio Probs
Re: Radio Probs
When the robot is disabled, all joystick and switch input is passed along normally. It's only the outputs that are suppressed. You can see this behavior using a Dashboard program. In autonomous mode, the inputs are indeed forced to neutral (all joysticks at 127, all switches off). But if your program doesn't do anything in autonomous, that can be a problem. Not doing anything means not shutting off things that were trying to move just before autonomous was selected. That's what Eric and Tom are trying to warn about. If you want to remove all autonomous actions, make sure to leave in the part at the beginning that sets all the pwm outputs to 127. Otherwise, a mistrimmed joystick or flipped switch can cause things to start moving and not stop until the teleoperated code starts running. Here's another piece of useful advice: if you have limit switches to protect mechanisms from moving too far, put the code to read the switches (and take action based on them) in the Process_Data_From_Local_IO() function, and call that function from within the autonomous loop. The default code only calls it when in teleoperated mode. |
Re: Radio Probs
| Ham Radio and Radio at FIRST | bcieslak | General Forum | 41 | 06-04-2007 10:41 |
| T_Packet_Data.mx probs | Ryan O | Programming | 4 | 14-02-2006 00:34 |
| need 2003 radio/help with old radio | MaxM | Technical Discussion | 2 | 04-01-2004 15:31 |
| FM radio transmitter | Alexander McGee | Electrical | 11 | 29-10-2003 19:41 |
| radio transmitters | Arin | Technical Discussion | 2 | 18-12-2002 01:59 |
