Re: Windows Vista Networking Problem
Originally Posted by mtaman02
I just discovered a problem with Vista's Network Map where when I initially set the network up on them I used Public instead of Home so I have to delete the old network connections and set them up as a private connection so they can see the network map better.
You don't need to reset everything! If you open Network and Sharing Center then across from the network name you will see a Customize link. You should be able to change that setting there.
Eric Haskins KC9JVH
