Go to Post A good teacher always needs to be a good student - Redhead Jokes [more]
Unread 12-03-2007, 22:59
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: AC Adaptor?
Yeah.... This whole thing doesn't sound to promising...
Sure, the battery might be rated at supplying so many amps, but when a motor turns on, it spikes way more than this. That's why the 'motorcycle' batteries that we use are so convenient; They can handle the high current spikes. I just don't think a AC-DC converter can handle this... Now maybe a system where its an AC-DC converter with a battery to handle the high current spikes... Kinda like the IFI 7.2v charging circuit, where the input voltage and the battery are used (but perhaps a better designed circuit... If we could only put in the one diode to prevent the battery from backcharging the robot... [/OffTopicRant]...)
Just some off-the-top-of-the-head thoughts... I could be completely off-base.
Jacob
Unread 12-03-2007, 23:07
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Re: AC Adaptor?
We have two wall-wart adapters which we use for testing the electronics. One provides 9v at 1/2 amp for the backup battery, and the other provides 12v at 1.5 amps for the RC. This works fine for testing the electronics, camera, sensors, etc, but will NOT run any motors.
Think about this -- the battery on the robot goes through a 120 amp breaker. That's a good indicator that to run it (with full motors) off of wall current, you'd need a power supply capable of providing 120 amps!
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 12-03-2007, 23:43
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: AC Adaptor?
Al's reply got me curious...so I connected a lab power supply to an RS540 mabuchi motor (the BaneBots motor) and switched it on and turned up the voltage. With the current limiting set to 2.0 amps, the ammeter indicated a spike to about 1.5 amps, and running currrent of about 1.0 amps with the voltage adjusted to anywhere from a couple volts to 10 or so.
I think my estimate of 10 amps needed to test the system, having the motors without mechanical load on them, is probably reasonable, asuming you don't try to run more than two motors at once.
Unread 12-03-2007, 23:47
MrForbes's Avatar
AKA: Jim
Re: AC Adaptor?
Might be able to use an old computer switching power supply, they have decent regulation, and should handle 5-10 amps on the 12v circuit.
Unread 13-03-2007, 07:37
Re: AC Adaptor?
Guys,
Battery chargers rarely put out a pure DC voltage. Never use them for power supplies. Often they put out a pulsed DC that averages about 13 volts but peaks much higher. Popular 50 amp chargers just connect a few diodes to a big transformer and add a few lights and an ammeter and call it a day. Remember that a wet or gelled cell battery will charge (current flows) if the input voltage exceeds the battery voltage. That is why 50 amp chargers are not allowed for our batteries as the high current is capable of destroying the battery. (read that catastrophically) The charger supplied in the kit is a smart charger and won't even turn on unless a valid battery is connected and in need of charging. The internal electronics test the device connected before supplying full output current.
As for the compressor, start current is about 25 amps while run current is about 10 amps. Again, start current on the Chalupas or the Fisher Price is over 95 amps. With many of the modern power supplies, the start current (of even one motor) will force the supply into current foldback or just simply trip the breaker. The supplies that go into current foldback will not go back to normal output until the load is removed or the power is reset.
And you don't want to turn on a power supply at a low voltage and run it up with the electronics. For starts the RC is disabled until the input voltage is above 8 volts.
Although the breaker is rated at 120 amps, if you look at the curve you will see that it can handle a 600% overload for a few seconds and can handle almost 200% for 40 seconds.
Unread 13-03-2007, 10:12
MrForbes's Avatar
AKA: Jim
Re: AC Adaptor?
Interesting....so just for fun I connected that RS540 motor to a switch, then to the 12v (at 8 A) output of an old 200W computer switching power supply. I turned on the supply, and the motor jumped and started turning, and kept turning.
This motor is rated at 0.95 A no load current.
Would the current spike at startup of the Chalupa (CIM) motors be any less than 95 A if they were under control of a Victor, as in real life? (in the situation of no mechanical load)
Last edited by MrForbes : 13-03-2007 at 10:56. Reason: added leading zero to 0.95 A
Unread 13-03-2007, 11:37
Re: AC Adaptor?
Squirrel,
The stall current for any motor is the start current since a motor that is not moving is by definition in stall. With no load the current spike is rather short and for this motor, the stall current is only 42 amps even though the no load is 1 amp. (from the Banebot website) Even a motor with a transmission that is not connected to anything still has some loading so it is likely that the computer power supply would not be able to start a motor coupled to a transmission. The caps in the output of your supply are the part of the power supply that is delivering current during that critical startup. If the current demand was higher or the value of the output caps were lower, the result would not be the same. What would be interesting is looking at the power output on a scope when you start the motor. This should show a significant drop in the output during the start time of the motor. The Chalupa motors are much higher current having 129 and 133 amps stalled respectively, as I remember. Run current, no load, is a little higher but the big difference is the amount of mass at start compared to the Banebot RS540. The armature of the larger motors may weigh more than the whole Banebot motor.
Unread 13-03-2007, 11:55
MrForbes's Avatar
AKA: Jim
Re: AC Adaptor?
That sounds about like how I thought it worked.
Can the stall current be estimated by applying Ohm's law, using the resistance of the motor, and the nominal voltage?
And could one add a large capacitor to the power supply output and be able to get a CIM turning?
as for the torque to turn a transmission, if you wanted to test the electronics, there really is no need to have the motor installed....my understanding is that the original question is how to test just the electronics without the hassle of having to deal with a battery. If the robot is assembled, the battery is not a hassle to deal with, as it is mounted in the robot, and easy to connect.
Unread 13-03-2007, 12:30
MrForbes's Avatar
AKA: Jim
Re: AC Adaptor?
I put the setup on a scope, and as you predicted, the power supply voltage does drop significantly, to about 6 volts as the motor is switched on. Also the filtering at the switching frequency gets pretty bad.
I don't have a storage scope, so I can't offer any pictures.
Unread 13-03-2007, 13:06
Re: AC Adaptor?
The series resistance of the motor is also complicated at startup with the inductance of the windings and the back EMF developed in the armature. The tough part about brush type motors is that generally, more than one winding is contacted by the brush assy. Due to this switching, the series resistance and inductance changes as the armature turns. I believe for testing the factory takes several readings and then takes the highest one for stall current. Series resistance is also affected by the shape and wear of the brushes and a variety of other factors. To measure the series resistance takes a device that will measure down into the fraction of an ohm range. A typical Fluke will not get you close to the actual resistance. At 100 amps at 12 volts, for example, the series resistance would be 0.12 ohms. (The contact resistance of the leads could affect a reading that low.)
It is possible to add capacitance to the output but there is a down side to that. The inrush current for the power supply goes up as you add to the output. That could pop the fuse or cause the supply to clamp for over current when you turn it on.
The best method of testing is a battery. You can breadboard a test setup using all of the electronics, breakers and the motors(sufficiently secured to the board) and check everything that way.
Unread 08-06-2007, 22:25
Rapt0r9's Avatar
Rapt0r9 Rapt0r9 is offline
AKA: Tyler
FRC #0747 (Flight Crew)
Rapt0r9 will become famous soon enoughRapt0r9 will become famous soon enough
Re: AC Adaptor?
Well, if you were to create a rectifying circuit to invert the AC to DC, you would need quite a bit of power from the AC line if you are going to run the entire bot off the line.
If you can find components rated for the current that you are going to draw, you can build a simple inverter using a transformer, rectifier (Diode Bridge), capacitor, and voltage regulator. The last two aren't absolutly nessecary, but they help to even the output voltage of the rectifier.
Personally, we use a car battery with a set of jumper cables to run motors before we wire the whole thing. This is convienient because we can just raise or lower the screw mech with out needing to install victors, an rc, breakers, and wire the it all.
BS Information Technology - NJIT (2009 - )
Team 869 (2004 - 2008, 2011 -), Team 1811 (2010), Team 869 (2009), Team 613 (2009 - 2010)
"Nothing in this life worth having comes easy."
Unread 10-06-2007, 10:44
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
Re: AC Adaptor?
To run our lights this year one of our mentors helped us rig up a system that had the battery on the charger as it delivered power. It served as an AC power supply for the light, but the battery protected the system from inconsistencies in the AC supply from the charger.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 10-06-2007, 11:01
Re: AC Adaptor?
Ed,
That is a still a chancy situation. In most cases the battery provides enough stabilization to keep the charger from producing higher than normal voltages. Keep in mind, though, that chargers still must output a voltage higher than the battery in order for charge current to flow to the battery.
Raptor9,
Please be advised that a simple rectifier fed from the line voltage still has the ability to place the supply at 110 VAC above ground depending on the way the electrical power is wired. Transformers of some type are needed to isolate the power line from circuitry that humans can contact.
Unread 12-06-2007, 13:26
Mr-Shutter's Avatar
Mr-Shutter Mr-Shutter is offline
Audiophile
AKA: David
FRC #0612 (Chantilly Robotics)
Mr-Shutter will become famous soon enough
Send a message via AIM to Mr-Shutter
Re: AC Adaptor?
A DC battery charger will NOT run your robot. It uses low current to charge the battery and is not advised to try and run you bot off of it.
Unless you have superior knowledge of AC-DC PSU construction, don't make your own.
Cough up the cash and buy a nice PSU.
For test boards, with little equipment
I mean, for a test board, running like 1-2 motors, use this! ( I doubt that the large motors use 40 amps)
http://myrcsupply.net/index.php?main... ucts_id=13383
or for 2-4 use this
http://myrcsupply.net/index.php?main... ucts_id=13008
They are equivalent to a car battery
Don't worry about blowing a fuse on the PSU's...
For the WHOLE robot
I like this one http://www.v-infinity.com/adtemplate...bcatky2=320934
It has what I believe to have sufficient current for the bot, and a lot of safety features built in, preventing damage top you, the bot, and the PSU.
Hook up a current meter to the bot and see how much current you draw with everything on. You’re going to want a PSU that can handle a little more then that amperage.
I see in logic, Black and White
Vision Sensor Power Adaptor ? CircularLogic Programming 8 17-01-2007 17:31
Power adaptor for the OI archiver 2000 1 23-06-2002 23:27
Need pinout for tether adaptor archiver 1999 4 23-06-2002 21:55
