Go to Post We'll defintely be working on both the balancing 2 wheel robot, the 6 legged robot, and the wood chassis 8 wheel drive robot ideas this fall. - MrForbes [more]
Go Back   Chief Delphi > Other > FIRST Lego League > Lego Mindstorm Discussion
Unread 10-06-2007, 19:22
cooker52's Avatar
cooker52 cooker52 is offline
Cookie
AKA: Seth Cook
FRC #4272
cooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant future
Send a message via AIM to cooker52
Re: What does it take to brick an RCX (no pun intended)?
I have never had a problem with my RCX. The only problems I have had is a messed up touch sensor (came like that) and what I'm going to build next. The other thing is that I don't usually watch my battery power. Always keep your program files backed up, otherwise, you are SOL.
I will never be able to leave 1501. Trust me, I did and I came back.
“If you worried about falling off the bike, you’d never get on.” Lance Armstrong
Monocoque, what a beautiful thing.
Unread 10-06-2007, 20:16
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
I don't think I'd worry too much about the Mindstorms RCX bricks.
I've been involved with FLL since 2002, and I've never seen any of the students I've mentored break any of them. I've seen them drop them (multiple times!), put all the batteries in the wrong direction, plug motors and sensors on the wrong ports, plug the motor output onto the sensor inputs, and the list goes on and on. (Leave it to 12-year old kids to find as many ways as possible to try to void the warranty...) All stories short, they all survived.
Generally, the motors are pretty robust as well. Only twice I've seen kids drop them and shear the shafts off the motors, and once there was a kid who would always try to attach wheels to the motor and manually spin it as fast as possible (stripping out the gears on the inside). In normal use, as long as they're geared down correctly, they should never burn out.
Art Dutra IV
世上无难事,只怕有心人.
Unread 10-06-2007, 21:34
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
I had a fence climbing bot fall 15 feet onto a concrete surface without any serious damage. The same RCX has survived 7 years of FLL on a team that:
-likes fast robots
-uses the "ram into wall to correct angle" approach to self correcting.
In general, mindstorms components are quite strong. I've only had one out of something like 25 motors burn out, and that was in an experiment to test the strength of the motors that looked kind of like this The only real problem I've had is with the toutch sensors jamming or becoming unable to detect a push after repeated, strenuous use, such as the wall hitting described above.
In my experience, RCXs acting weird are more than likely IR issues. I have seen robots at FLL competitions do some REALLY weird things due to IR focusing cameras. As others have said, changing batteries or realoading firmware usually solves the problem
Unread 10-06-2007, 21:37
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
[randomLegoAnecdote]
Yeah, I once spray painted a bunch of touch sensors (I thought I completely covered the button part), and apparently some of the paint got inside.... because the sensors stopped working. But that's not normal classroom use.....
[/randomLegoAnecdote]
Jacob
Unread 11-06-2007, 01:02
EricH EricH is online now
I've seen the "impact test onto concrete" before, on the team I mentored, and the RCX worked. Another team tell about the "punt test"--apparently the kid who did that was told to take the RCX out before doing that again, but the RCX survived.
Batteries and firmware--change the batteries fast, you don't need to reload the firmware.
IR: We had issues our first year with an FLL team. The program worked right sometimes but not others. Then one of the dads shut off his camera's autofocus, which used IR ranging. The robot worked much better, for some odd reason. (Also, there are LEGO remotes. Keep those hidden/unpowered.)
Unread 11-06-2007, 11:10
Brandon Holley's Avatar
Heres a quick story...
way back in 2002 was the first year nationals hosted a lego competition, and low and behold our lego team was invited to compete. We packed our bot into hard plastic cases and were on our way. Someone was supposed to take the robot out of the big box that was being checked on to the plane.
No one did...thus, the robot underwent the trip on the plane from the luggage compartment. When we got to florida, we opened the box only to find a pile of lego pieces and an RCX....the RCX, worked flawlessly...even all the programs were intact...the robot, well lets just say we spent a considerable amount of time that night rebuilding her.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
what does it take to start a qualifier Dantvman27 FIRST Lego League 3 17-04-2007 14:59
What does it take to be considered and elite team? Jim Schaddelee General Forum 20 24-06-2005 10:59
How long does it take you to recover? sanddrag Chit-Chat 16 02-03-2005 02:01
Sometimes it DOES take a rocket scientist archiver 1999 5 23-06-2002 23:02
How long does it take ? archiver 1999 11 23-06-2002 22:38
