Go to Post ....you can't go to a single FIRST event without someone saying "Hey, Look! It's SuperNerd!" - [more]
Unread 10-06-2007, 19:24
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Windows Vista Networking Problem
Originally Posted by mtaman02 View Post
Rather then create a new thread I and search for the one that was posted by another CD' I'll just post an additional question here.
The Problem: When there is an Ext. Drive attached to the system and I reboot / or cold boot the system I get the following message; NTLDR Missing Press CTRL ALT Delete to Restart. I follow said instruction and get the same message. If I unplug the Ext. Drive and then boot the system everything boots up normally and everything is fine and well when I plug the drive back in, but the message will re-appear each time the system is restarted / booted up.
As of right now I'm searching MS to see if there is a patch to fix this problem. Just curious though if anyone else has had this issue. It's a pain to constantly remember to unplug the drive when booting up.
Sounds like that ext. drive is trying to load Windows NT/2000/XP. NTLDR is the executable run to start Windows. There should be a way to remove the info from that drive, so it will ignore it, but I don't remember how.
You can change the boot order in your BIOS so it loads from the HDD before external drives. Watch the screen a startup. It should have instructions how to enter BOIS setup.
Eric Haskins KC9JVH
Windows Vista ThomasP Chit-Chat 15 01-02-2007 07:16
Windows Vista RC1 Tom Bottiglieri Chit-Chat 7 06-10-2006 13:44
Windows Xp networking Problem BobcatProgramer IT / Communications 17 30-09-2005 15:27
Windows vista!!! [527]phil General Forum 27 25-07-2005 17:01
Home Networking on Windows XP D.J. Fluck Chit-Chat 16 14-09-2002 14:21
