Go to Post Gears will win matches. Climbing will win events. Fuel will win championships. - Taylor [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 11-06-2007, 23:20
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: buying new laptops
[tablet PC, Vista, Gateway rant]
I'm running a Gateway cx210. The bottom of the line is $1100, but if you watch for a sale you can easily get it for $1000 or even $900. I have the 12 cell battery(standard is 8 cell) which gets up to 6.5 hours(depend on optical drive use) of battery life when I put in Power Saver(WINDOWS VISTA ONLY) mode. In High Performance(same as XP) I still get around 4 hours.
Keep in mind the CX210's base line is: 1.86 Core Duo, 1024mb RAM, 80gb HDD, CD-RW/DVD Combo, Wi-FI a/b/g, Vista Home Premium.
NOTE: I also have the ATI graphics card, which also uses more power than the less powerful Intel option.
I also suggest this unit because I LOVE convertible laptops. You have no idea how wonderful it is ,for graphics work, taking notes, scouting the pits, or anything else, to be able to draw/write on the screen.
Also this unit has the option to get Windows XP Tablet Edition(pro + tablet functionality), for $100.
I STRONGLY recommend getting Vista for a laptop. As I mentioned above the power saving features of Vista a amazing. Unless you know a product you want to run has compatibility issues, get Vista.
Vista does have a learning curve, but once you learn it you will find Vista really is better, and a lot prettier, than XP.
I have run all Lego Mindstorms software on Vista without any issues. I did need to install a driver update for the USB RCX tower, but that was easy.
[/tablet PC, Vista, Gateway rant]
If you don't like to unit I mentioned above, which I can understand, find the cheapest computer you can find, and replace it when you need something better(or it gets broken).
Eric Haskins KC9JVH
HP Laptops Beth Sweet Chit-Chat 23 28-05-2006 20:53
Programming laptops [527]phil Programming 24 22-08-2005 12:28
Laptops Mike Chit-Chat 23 30-05-2005 19:52
Laptops/Palms Genome17 Rules/Strategy 5 06-04-2002 01:27
