Go to Post Kickoff features the joys of discovery. Ship date features the fear of utter failure. - Koko Ed [more]
Unread 12-06-2007, 09:22
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Unibody/Monocoque Construction
Yep, 1501 would be a team to look at. There was a good section on them in "Behind the Design" which I just bought yesterday.
Unread 13-06-2007, 00:04
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
One of the students made up this page and they did a video. I dunno if that helps or not..
http://www.huntingtonrobotics.org/in...d=1&Itemid =2
Video Link
http://www.huntingtonrobotics.org/in...=1&key=1&hit=1
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 13-06-2007, 00:15
Controls Engineer
AKA: chakorules
No skin pictures of 2005 robot.
ID:	5586  Click image for larger version
ID:	5587  Click image for larger version
Favorite CD quote:
Unread 13-06-2007, 00:30
AdamHeard's Avatar
Lead Mentor
Video Link
The page is pretty impressive and well done for a student.
Just curious, since then have you moved on to designing the parts with the sheet metal features of inventor, or do you still make a 2d sketch and then transfer to plywood? Or was the plywood just a medium to transfer the unfolded sheet metal pattern to sheet metal?
Unread 13-06-2007, 00:53
Controls Engineer
AKA: chakorules
2005 and 2006 robot are all 2D 1:1 scale plots transferred to plywood, then sheet metal.
2007 robot was drawn in 3D for the first time. I can't remember if they plotted and used the 3D drawings from inventor or not. One of the students was showing me the sheet metal tool in inventor (me personally I don't have a clue how to use the software), and acutally I think it was a student from team 1720 that was showing me ;-)
2007 was different in a way that it was alot of tubing, the same tubing they use in the landing gear on the airplane. Chromoly tubing, then the wings are sheet metal with rib spars. So it was a bit different than the 2005 and 2006 robot but still based on airplane parts. ;-)
Favorite CD quote:
Unread 13-06-2007, 01:00
AdamHeard's Avatar
Lead Mentor
You guys are using Chromoly? wow... that stuff is heavy, I can't really tell from some pics I just looked up, but what size tubing was it and was it worth it compared to a larger piece of aluminum tubing? Is it something worth doing again? I'm not criticizing, I'm just trying become more familiar with construction techniques
Don't put off learning CAD... I did for two years and it was totally not worth it... It seemed intimidating to me, but I just took the tutorials in inventor and fiddled around; Now I've become pretty good at it. If I can do it as I high school student, you should take some time to learn it. Unless you're not a M.E.; in which case, sorry for harassing you.
Unread 13-06-2007, 01:06
Controls Engineer
AKA: chakorules
It's not as heavy as you think. Our whole tube frame was somewhere around 36 lbs I think. I am not for sure on that. But I was very impressed. The biggest down fall of the tubing was the welding. We had one mentor and two students that could weld it, the process was a bit slower than 10 guys with rivets guns for sure, but I can't complain, the end result was amazing to me.
I am not an M.E. I am a Controls Engineer. About the extend of my cad is AutoCad Electrical 2008 (<<<--use to be VIA, until AutoDesk bought them out) and I like Google Sketchup. I like Sketchup and have been learning the concept of 3-D drawing, maybe that will carry over to Inventor, if I ever have a need to use it. So far, drawings electrical prints in 3D some how doesn't fit into my schedule so far :-)
Although I wonder if the electricans would freak out if I gave them a 3D wiring diagram???? hmmm.....
Favorite CD quote:
Unread 14-06-2007, 17:29
robotguy67 robotguy67 is offline
AKA: Mike Smyth
#1501 (Team T.H.R.U.S.T.)
robotguy67 is an unknown quantity at this point
I was the mentor that helped with the welding of the frame last year. Chromoly can be built very light if done properly. That's why it's commonly used in race car chassis, high stress points in air frames, etc... Given our design goal (killer lift bot), a fully monocoque frame was not appropriate last year. The tube frame could be designed much faster than it would have taken to do it fully monocoque. Aluminum tubing could have been used, but we didn't have the capability to weld it in-house and I'm not sure it would have ended up much, if any, lighter keeping the same strength. The total weight of the tube structure was #25, I believe - and this included the 8 big rollers, 16 bearings and 16 pillow blocks for the main lift. In all but a few small tubes, the wall thickness was only 0.035". This kept the weight down and all the tube triangulation made the entire frame and lift very stiff. The main tubes of the center tower are 1" OD. All the other tubes are either 5/8" OD or 3/8" OD. At one time there was a video on youtube of our bot lifting a 300lb guy on one wing without any showing any flex. As the primary designer of the tube structure I would definately use chromoly again if apprpriate for the application.
Mike
Unread 14-06-2007, 17:52
AdamHeard's Avatar
Lead Mentor
Mike
that's the kind of info I was looking for; Very good use of it. Could you post some better pics of the frame than what is in CD-media currently? you can only see the uppermost portion which doesn't reveal much. Also, when you say 25 pounds, how much of the robot frame is that? Is the chromoly weldament the entire frame, or are there other pieces in there?
If you weren't building that robot, but instead building a standard 6 wheel drive base with some sort of maniupulator that didn't affect the base shape, would you prefer the monocoque method, or a welded chromoly frame?
Unread 14-06-2007, 22:13
cooker52's Avatar
cooker52 cooker52 is offline
Cookie
AKA: Seth Cook
FRC #4272
cooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant future
Send a message via AIM to cooker52
I belive that is the frame without the two pneumatic cylinders and the two gas struts. I could be wrong, but I believe that was how we measured it, the frame straight up, nothing added.
Can't tell you that, this was my first year and I'm still learning lots about monocoque design, and enjoying every minute of it
I will never be able to leave 1501. Trust me, I did and I came back.
“If you worried about falling off the bike, you’d never get on.” Lance Armstrong
Monocoque, what a beautiful thing.
Unread 15-06-2007, 00:06
AKA: Mike Smyth
The entire frame was chromoly and consists of two main pieces - a main "tower" and a "trolley" that rolls up and down the tower. These two pieces together are about 25lbs with the rollers and bearings. The lifting platforms (aka - wings) used monocoque construction (mostly .040" 6061 T6). These were made just like aircraft wings - skin over two main spars made from sandwiched aluminum. The actual wing pivots are made out of 0.1" thick chromoly plate - these plates ARE heavy, but very strong. The first set of wings were 17lbs each, I believe. I think the lightened wings were about 15lbs each (you may have seen us frantically finishing these in our pit in Atlanta). Other than these main parts, of course we had our control panel (monocoque box), monocoque battery box and pnuematics panel, two outriggers also made of chromoly (2-3lb each, not included in the 25lb), transmissions, wheels, etc... I'll have to let one of the other team members post some good pictures of the frame.
If we were doing a more standard base, we would have used monocoque. We used entirely monocoque the two previous years - frame and manipulator/shooter. It goes together much quicker and is plenty strong if you have a "normal" shape. To accomplish our design goals last year, we needed a large part of our robot to move 12" and it needed to support large internal forces (upwards of 1000lbs) from the wings and it needed to have a big hole through the middle of it. This could have been done with monocoque given enough analysis and design time, but it just wasn't practical to do in 6 weeks. The tube structure was much easier to design and is more durable than monocoque would be in this application. The chromoly tubing is tougher than mild steel, so thinner wall tubing tubing can be used most places which keeps the weight down.
Monocoque is ideal for distributed loads - like the areodynamic loading of an aircraft wing. The rolling trolley in this robot concentrates very large forces on just a few points (the rollers). Using monocoque, these points would require some fairly thick material along the roller tracks to distribute the point loads. We may have saved a few pounds using monocoque for the lift bot, but it would have taken a lot more design effort and for the same weight, the tube structure is a lot stiffer.
Mike
Unread 15-06-2007, 16:38
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Thank you all for sharing your design tips and techniques--there is a lot of great information here, showing off some quality work.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 14-06-2007, 23:24
Jim Zondag's Avatar
Jim Zondag Jim Zondag is offline
Team Leader
FRC #0033 (Killer Bees)
Jim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond repute
To Follow up on Woody's note above:
Team #33 has used a Structural Sheet Metal chassis design on several of our robots. Not exactly a monocoque, but similar. Like elaborated above by other teams; this is the strongest and lightest way to make many elements of a Robot. Our structural Chassis module is under 9 lbs including axles, motor mounts and battery tray, and it is very strong and very rigid. It has easily survived over 13 FIRST events of other teams relentlessly pounding on us and I have yet to have a failure of any kind. This design is a mix of .063", .050" and .040" T6 6061 Aluminum. We use 5/32 Alum/Alum Rivets for most of the jointery any use 10-24 screws with Jnuts for the wheel enclosure in case we want to go in an service the chains. We plan to post the complete set of CAD models, shop drawings and Assembly instructions to our team website later this summer (www.killerbees33.com)
ID:	5589  Click image for larger version
"To learn what is possible, we must attempt the impossible." Arthur C. Clarke
Unread 14-06-2007, 23:56
AdamHeard's Avatar
Lead Mentor
Wow, that is beautiful... It's hard to imagine that whole frame weighs less than my 12lb battlebot.
Are the wheels sheet Al as well? How much do they weigh?
Unread 15-06-2007, 20:27
woody's Avatar
woody woody is offline
Too much metal for one hand! \m/
woody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to behold
We used the standard 8 x 1 inch IFI wheels with great success. I'm not sure on the exact weight, though.
"The greatest of all mistakes is to do nothing because you can only do a little; do what you can." - Sir Sidney Smith
Rack Construction newklius Rules/Strategy 26 21-01-2007 13:47
Gearbox Construction John Gutmann Technical Discussion 6 04-06-2006 08:25
Construction materials mechanicalbrain Technical Discussion 46 26-09-2005 16:25
Website Construction David66 Website Design/Showcase 9 11-01-2005 19:19
Offsite construction archiver 2000 3 23-06-2002 23:13
