Go to Post I'm not worried about talking to the robot, but I am worried about when the robot starts talking back... - Moros [more]
Unread 12-06-2007, 13:26
Mr-Shutter's Avatar
Mr-Shutter Mr-Shutter is offline
Audiophile
AKA: David
FRC #0612 (Chantilly Robotics)
Mr-Shutter will become famous soon enough
Send a message via AIM to Mr-Shutter
Re: AC Adaptor?
A DC battery charger will NOT run your robot. It uses low current to charge the battery and is not advised to try and run you bot off of it.
Unless you have superior knowledge of AC-DC PSU construction, don't make your own.
Cough up the cash and buy a nice PSU.
For test boards, with little equipment
I mean, for a test board, running like 1-2 motors, use this! ( I doubt that the large motors use 40 amps)
http://myrcsupply.net/index.php?main... ucts_id=13383
or for 2-4 use this
http://myrcsupply.net/index.php?main... ucts_id=13008
They are equivalent to a car battery
Don't worry about blowing a fuse on the PSU's...
For the WHOLE robot
I like this one http://www.v-infinity.com/adtemplate...bcatky2=320934
It has what I believe to have sufficient current for the bot, and a lot of safety features built in, preventing damage top you, the bot, and the PSU.
Hook up a current meter to the bot and see how much current you draw with everything on. You’re going to want a PSU that can handle a little more then that amperage.
I see in logic, Black and White
Vision Sensor Power Adaptor ? CircularLogic Programming 8 17-01-2007 17:31
Power adaptor for the OI archiver 2000 1 23-06-2002 23:27
Need pinout for tether adaptor archiver 1999 4 23-06-2002 21:55
