Re: Using IFI Controller witout Operator System
Step1: Connect OI to controller on robot. Forget about autonomous mode. After all the OI just sends the value of the joysticks to the controller, right. The code assigns it to the motors. If you don't assign it it will not run.
Step2: Use your sensors to determine what you want to do. Like if the sensors sees the light then assign a value to you PWM outluts where your motors are. No matter what mode you are in if you assign 255 to a PWM the motor will run. I suggest you include a kill switch. Use a switch like a plug. If the plug is out the robot stops. // include at bottom of code. if( rc_dig_in01 == 1 ) { // switch is open not closed, closed = 0 yes backards its digital pwm01 = 127; // stops motor pwm02 = 127; // stops motor } In addition I gave a workshop in 2005 on writing autonomous programs. http://first.wpi.edu/Workshops/2005w...nferences.html If you are still stuc that you need autonomous put this at the top of your program. autonomous_mode = 1; This will force on the autonomous bit. It is not necessary but put it on if you like. |
| Building an arena controller | CJO | Control System | 32 | 29-03-2005 07:04 |
| IFI Loader Problems | BrendaB | Programming | 3 | 24-01-2004 22:45 |
| Help On Coding 2K1 Controller | GregTheGreat | Programming | 9 | 05-12-2003 18:35 |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
| How much code can an IFI controller handle? | Larry Barello | Programming | 7 | 10-02-2002 19:06 |
