#13
Re: Using IFI Controller witout Operator System
Please review my post on the first page. You do not have to run this in autonomous mode. It will run fine by your code in normal mode.
The difference in autonomous mode is a bit is set on called autonomous_mode. If this is 1 then your code takes over control of the robot. If the bit is not on then you allow the controlls to operate the robot. But you can allow you code to run the robot all the time by itself without anyone operating it. |
| Building an arena controller | CJO | Control System | 32 | 29-03-2005 07:04 |
| IFI Loader Problems | BrendaB | Programming | 3 | 24-01-2004 22:45 |
| Help On Coding 2K1 Controller | GregTheGreat | Programming | 9 | 05-12-2003 18:35 |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
| How much code can an IFI controller handle? | Larry Barello | Programming | 7 | 10-02-2002 19:06 |
