Go to Post FIRST was the best thing that accidentally happened to me. - Stephen Kowski [more]
Unread 13-06-2007, 21:44
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Telescoping arm
how do the work when you have 2 chains and 3 segments like 233 in 2004 and 2005
Unread 13-06-2007, 21:59
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Telescoping arm
Basically, you have a pulley or sprocket on the top of the outermost segment, one at both the bottum and top of the middle segment, and an attatchment point at the bottum of the innermost segment.
The same setup is used on an 80/20 or similar material elevator, like team 25's this year.
Unread 13-06-2007, 22:39
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Telescoping arm
You might find this presentation by Greg Needel from the 2006 Conference Archives to be interesting. He covers a lot of different concepts in arm design in it, check it out, I think what your asking is covered in it.
Unread 13-06-2007, 22:51
Jeff 801's Avatar
Re: Telescoping arm
that is one but what I mean where you have 2 complete chain segments
Unread 14-06-2007, 00:18
meiv4 meiv4 is offline
The Jimmy
AKA: Jimmy Dolengewicz
FRC #1388
meiv4 is on a distinguished road
Send a message via AIM to meiv4
Re: Telescoping arm
I havn't actually gotten to look at anyone elses but this is one way i thought up.
the red chain is attached to the bottom of the middle segment, goes over both the top and bottom of the outer segment and is powered by a sprocket (red lines). the second chain section (blue) attaches to the top of the outer segment ran over the top and bottom of the middle segment and is attached to the bottom of the inner segment.
pie = 8.53973422
Unread 14-06-2007, 00:23
Re: Telescoping arm
While I have not actually used the design you showed on a FRC robot, I strung up one of my LEGO robots to use the same design as you designed and it worked perfectly. With this design, all the segments are the same precent extended as all the others.
Unread 14-06-2007, 15:16
Jeff 801's Avatar
Re: Telescoping arm
but what do you do when you have a 3" 2" and 1" box tubing in side of one another like this http://www.chiefdelphi.com/media/photos/20400
and http://www.chiefdelphi.com/media/photos/18173
Unread 14-06-2007, 16:08
AdamHeard's Avatar
Lead Mentor
Re: Telescoping arm
It looks more like 4-6", 2-3" and 1"... I think they have varied it slightly year to year, If you read through some of the discussions on the 04,05 and 07 robots from 233, I think it says what sizes they use. It's the exact same principle, except the sliders are inside of each other rather than next to each other.
Unread 14-06-2007, 17:00
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
Re: Telescoping arm
We (Team 343-Metal in Motion) used a three segment arm like 233 this year. We drove the first section with a lead screw and a cable was wrapped around two pullies on the second. (Similar to the diagram above). We used box tubing of 3X2" for the first stage, 2X1.5" for the second and 1X1" for the third. We had intended to do the cut outs like 233 but didn't need the weight so we left them whole. If you're looking for more details, PM me and I can send you the cad drawings.
- Gene Falendysz
Unread 14-06-2007, 23:26
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Re: Telescoping arm
This might help you out.
From our 2005 robot
http://www.chiefdelphi.com/forums/sh...98&postcount=6
EDIT: We used 3X3, 2X2 and 1X1
Robot pic: http://www.chiefdelphi.com/media/photos/20333
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 15-06-2007, 10:57
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
Re: Telescoping arm
The design you are inquiring about for the telescoping tower used 4", 2.5", and 1" tubing. I can elaborate on the chain routing if you like.
mike d
See Ya
Unread 15-06-2007, 14:41
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Telescoping arm
We traditionally have used widow tape to minimize the profile when we build extension arms. This style easily fits into a three piece extension.because it is only 1/8" thick and utilizes internal pulleys.
Pete
Thank-you 294 & 67
www.bobcatrobotics.org
Jeff 801's Avatar
Re: Telescoping arm
mike d
YES please !
Telescoping Arm ArmoredFairy698 Technical Discussion 17 14-06-2005 11:26
Chain Driven Telescoping Arm BadKarma Technical Discussion 8 05-06-2005 12:19
pic: Team 930 telescoping arm CD47-Bot Robot Showcase 1 13-02-2004 16:24
telescoping arm CharlieWilken Technical Discussion 45 26-01-2004 22:22
telescoping arm & ten second rule Ben Mitchell Rules/Strategy 4 18-02-2002 21:37
