Go to Post Engineering still can't beat Physics! - Manoel [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 14-06-2007, 18:02
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Website Hacking Problems
[Offtopic]Jimi Hendrix said "If a six truned into nine, I won't mind", but it appears the nine turned into a six. Wonder what he's say about that...
Anyway, the PI-O-Neers just love it...[/Offtopic]
I just uploaded a white paper on Password Security, this will help people create (and remember!) very strong passwords for multiple sites. Enjoy.
Don
Unread 15-06-2007, 02:23
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Originally Posted by artdutra04 View Post
Check the file/folder permissions of the root directory. If it's are listed as 777, this is a security problem. Change (chmod) them to 770 or 755. You can create subfolders with a chmod setting of 777, but only do so where your scripts actually need file creation/deletion/alteration permissions. If all you have in a directory is static HTML files that you alter via FTP, lock down the file permissions for that directory.
I take it you mean it is very bad if our httpdocs folder is set to 777? I'm sorry I don't know more about this kinda stuff, so thanks for any help you can give us!
[EDIT] I chmod(ed) it to 755
Unread 15-06-2007, 10:57
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If the root directory of your website is chmod'd to 777, and you are hosting your website on a shared server, it's possible that you could be compromising the security of your website. This could allow changes to be made to the root directory of your website, which is bad. So changing the permissions to 755 for the root directory is a good idea.
Basically, when a folder is chmod'd to 777, it means anyone can read, execute, or write files to that directory. The order of the numbers means [Owner] [Group] [User], each with a value from 0-7. Since we certainly don't want anonymous users being able to write files to the directory, we change the Group and User values to a lower value, which allow them to read and execute, but not write to that directory. Hence, we get a more secure file permissions value of 755.
Art Dutra IV
世上无难事,只怕有心人.
Unread 15-06-2007, 10:58
GRaduns340 GRaduns340 is offline
The Fruit Man
AKA: Gary
FRC #0340 (Greater Rochester Robotics)
GRaduns340 has a spectacular aura aboutGRaduns340 has a spectacular aura aboutGRaduns340 has a spectacular aura about
Send a message via AIM to GRaduns340
I didn't actually see what your problem was, but our site was recently hacked as well. It's been running on a CMS for ease of transfer to the next webmaster, so at first I assumed that either that or the forum was the loophole and that I would go about trying to find that. I later discovered, after talking with our private host, that it was a root access hack, and that all sites on the server had been hacked through the server's root user. We got hit pretty hard, as ALL web-based files (PHP, HTML, HTM...) were overwritten by copies that contained a meta refresh, redirecting our site to some foreign forum. I still can't delete some of them because of ownership and permission changes that were also made, but if that's what you're dealing with, you'll have to go through your host if you actually want to correct it.
Unread 15-06-2007, 11:29
Unregistered User
AKA: Kevin Forbes
Ok, thanks! I'm pretty sure the folder was set to 755 before the hacking started, so they probably got in through a security loophole in one of the older forums (I made several because I was new to this stuff)
Now we just have to wait and see if it gets hacked again....
Unread 15-06-2007, 11:40
artdutra04's Avatar
It sounds like they used an automated script to infect all your files; as such the changes in permissions might have been set to only PHP's "nobody" user. (Which would restrict access to such files to PHP scripts alone.) See if you can use PHP to do a site-wide crawl, read every .html, .htm, or .php file, str_replace() the "<meta refresh..."> crap with NULL or an empty character set "", save the files again, and then chmod everything to the permissions it should be set at.
EDIT: Basically, this is the exact reverse of their automated script.
Art Dutra IV
世上无难事,只怕有心人.
Unread 15-06-2007, 12:19
The Fruit Man
AKA: Gary
That's exactly what they did, and I could run through that, but I'm working with our host, and he's told me he will reset ownership for us. As it is, I can overwrite everything they did, I just need a couple thigns deleted that I don't have originals to overwrite with. It's not a big deal any more, just that at some point between now and next season it will be good for whoever takes over as webmaster for our team to have the right ownership.
Unread 15-06-2007, 15:09
slade24 slade24 is offline
AKA: Slick Daddy Ellis
AKA: Aaron Schultz
FRC #1370 (Blue Charge)
slade24 is on a distinguished road
Post Re: Website Hacking Problems
You might want to further go through and patch any security holes in scripts that you hand-wrote. Make sure nothing allows a user to inject headers (for example, in a email sender) or upload files with filetypes other than specific ones (ie: allow jpg, prevent .php or .asp or whatever).
If you are running on Apache (your gallery uses php files, so I will assume this is true), you can also use .htaccess files to block IP addresses of known offenders. A nice look at .htaccess can be found here -- they're quite useful for many things.
Also, I don't know if anyone told you otherwise, but your site is built using tables. There's nothing wrong with that, but if you are hoping to grow as a web developer, look into learning CSS and using it for layout as well as style. Alistapart.com (A List Apart) is a pretty amazing site for web design concepts in general. The table vs. CSS debate can be found here.
-- Time is my only enemy --
Middletown Robotics: Home
HELP! Website hosting problems. Tottanka Website Design/Showcase 27 04-02-2007 22:28
263's Computer Hacking Competition SeanCassidy Chit-Chat 31 29-09-2005 15:11
Using non joystick controls with Operator Interface (Hacking Various Controllers) Astronouth7303 Control System 58 02-02-2005 15:56
Talk about the 'hacking' here. Brandon Martus Chit-Chat 12 08-07-2003 15:53
Hacking The Segway MattK Dean Kamen's Inventions 16 31-07-2002 20:51
