Go to Post Brandon, can you make some sort of mind-reading device that i can just think "portal" and i'll go back? - Tom Schindler [more]
Unread 17-06-2007, 07:01
cdennisxlx2's Avatar
cdennisxlx2 cdennisxlx2 is offline
Team San Diego Web Liaison
AKA: Cameron Dennis
FRC #1266 (The Devil Duckies)
cdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to behold
Exclamation This isnt FIRST related but it would be really cool if someone could help me
I have an odd networking problem, hopefully someone here has seen this or something because i have never seen this like this before
Ok I have 4 computers in my home they used to all be networked with out any problem, I reformatted one to give to my little brother, when windows was finally installed I configured the computer into my work group. My main computer saw it but sharing wasn't configured for some reason, so i configured it, just after that my computer didn't see it anymore so i looked at it and it didn't even see it self in the network. so i started trying to reconfigure my work group on both comps well after doing that now my computer doesn't see anything nor itself either. but the other 2 computers saw each other when i hubed them through a 5 port hub and not my router as soon as i connected them to my router they didn't see each other so i figured it was the router, went out and bought a new one just in case, same issue, i have tried every freaken thing that i can think of, the sad thing is networks are my specialty. here are the main specs
-Computer #1 (main)--
Desktop
Windows XP Pro SP2
Win Firewall disabled
Norton Firewall enabled (have tired with it disabled)
-Computer #2--
Desktop
Windows XP Home SP1 upgraded to SP2
-Computer #3--
Desktop
Norton Firewall disabled (will not enable theres an issue with it)
-Computer #4--
Laptop
Windows XP Pro SP2
Saw itself on the network but only through wireless
-Router--
Linksys Wireless N WRT300N
-Modem--
Linksys Cable
Internet works through out but not file sharing
The network is setup in a Star Topology
any possible help is very much appreciated, any info you need feel free to ask, thank you
Team San Diego Robotics Web Liaison
Webmaster and Technical Advisor for the San Diego Regional Planning Committee.
Official Score Keeper for the San Diego Regional
www.sandiegoregional.com
www.frc1266.com
Unread 17-06-2007, 07:53
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Re: This isnt FIRST related but it would be really cool if someone could help me
Make Sure the IPX/SPX Protocol are installed on everybody. That protocol helps everyone see one another. Make sure all other Windows (Not Novell) Protocols are installed. Go into your Network Connections and right clip the one you are using on the Network (most likely Local Area Connection or something to that effect) and right click on it to select properties. From there you can install different protocols. Make sure all the PC's are on the same workgroup and sharing is properly setup.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 17-06-2007, 07:55
AKA: Cameron Dennis
done all of that, still to no avail
www.frc1266.com
Unread 17-06-2007, 07:58
mtaman02's Avatar
Is the Windows Locator turned on in all of the computer? The problem may be the computer and not the router. Maybe you setup the card wrong?
Volunteer Resume:
Unread 17-06-2007, 08:00
AKA: Cameron Dennis
yes it is on
www.frc1266.com
Unread 17-06-2007, 08:04
mtaman02's Avatar
Computer #4 saw itself wirelessly but no Hard Wire right? I can only think that either the NIC is shot, the Cat5 cable could be shot - highly doubt it or it's setup wrong. I'll have to think about this one.
Volunteer Resume:
Unread 17-06-2007, 08:07
AKA: Cameron Dennis
not when plugged into the router but when plugged into the hub it did and also saw comp #3
www.frc1266.com
Unread 17-06-2007, 08:08
AKA: Cameron Dennis
this has been hassling me for 3 days I've devoted more time to this then i do at work
www.frc1266.com
Unread 17-06-2007, 11:34
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
The first thing I would do would be to make sure I can PING each station.
You will need to know the IP address of each machine to ping.
I would also do a TRACERT to each station as well.
This will at least prove that they are in fact connected on the network and that network data can flow between them.
I would also make sure that your firewall/router is allowing Windows file and print sharing on the LAN side and NOT the WAN side of the connections.
TCPBUEI (Netbios over IP) is the protocol used over ports 135, 137, 138, and 139 TCP and UDP for Microsoft NetBIOS.
You certainly don't need IPX/SPX protocol unless you are running a Novell Netware Network which you aren't. So I highly recommend you remove those since they only slow networking down by adding an additional stack to process.
Also note that for some odd reason I have experienced in a peer to peer network that it can take several minutes to even an hour for a single machine to appear in the Network list. That's another one of MS's bad ideas about name broadcasting, name resolution, etc....
Make sure you have Client for MS Networks, File and Printer Sharing for Microsoft Networks, and TCP/IP protocols bound to the NIC you are using. Also make sure the WORKGROUP name is the same for ALL machines and that each machines name is unique.
Outside of that, then it's either bad cables, bad nics, or bad ports on the router or any combination there of.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 17-06-2007, 15:44
AKA: Cameron Dennis
when i ping them i get a 100% fail (times out), ive replaced cables, nics, and routers, my firewalls are set up to permit file share, the workgroup is the same on each i cant do a TRACERT if the pings arnt going through, i should also mention that every computer has a connection to the net
www.frc1266.com
Unread 17-06-2007, 20:52
Phalanx's Avatar
Okay, if you can can't ping them, yet they all have access to the internet then it is a firewall/router issue. Whether it's the router or some software firewall on the Windows machine I can't tell.
I would take the machines, reconnect them to the hub, connect that hub to your firewall/router. Then see if you can ping and/or tracert the machines connected to the hub. This may eliminate or confirm the firewall/router as to where the issue lays.
If all of your stations can ping and tracert each other when connected to the hub and they have access to the internet too, then issue is within the firewall/router. If not, then it is something in the configuration of the machines that can't communicate with each other.
Also some firewall/routers need to know the "workgroup" or "windows domain" that they participate in otherwise they won't allow the peer to peer networking. I'm not sure if the router you have is one of those or not.
Could this really be a picture of Dean not in a jean jacket? Michael Hill Dean Kamen's Inventions 9 06-01-2006 10:56
not robotics, but help would be appreciated pryoplasm Electrical 26 02-06-2004 07:14
Could someone look this over? Ryan M. Programming 12 08-02-2004 12:22
Very Cool new robot! (Non-FIRST related) Elgin Clock General Forum 1 13-02-2002 02:12
really cool idea (but i need a question answered) Ghetto_Child Technical Discussion 1 01-02-2002 21:59
