Go to Post your time is better spent in the stands, watching what the robots actually do, as opposed to listening to the builders talk about what they're [I]supposed[/I] to do. - sanddrag [more]
Unread 19-06-2007, 22:46
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: Smithy or other Benchtop Mills/Lathes/CNC
Maybe take a look at the turnkey CNC machines from Industrial Hobbies. I have never seen them in person them but they look interesting on the website.
Unread 20-06-2007, 14:59
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Interesting you mention Smithy and Microkinetics. In Fall of 2003, I was granted an opportunity to spend $5000 in "school supplies" in about 1 day. We didn't have any mill or lathe (nor machining experience), so I found the Smithy in the MSCDirect catalog and said, hmm... looks like the all-in-one would do the trick. Well, we still use it today, but there is something to be said about, you get what you pay for. For most of simple milling work - its great, stick the DRO on it, lock down your table axis and mill some mounting holes or slots. Cory mentioned one important aspect, as soon as you raise the "neck", you lose your zero. A big pain when you change out a drill bit/ chuck for a collet/endmill. But you learn it's capabilities. I've been the most dissappointed with the lathe function. It is extremely hard to center the chuck and tailstock. Even when we have a professional machinist (retired) do it, the best they could do it +/- 0.003" which is unacceptable for small gear work. We pretty much just use it as a Mill/Drill only.
That same year, we had another administrator say that we could spend another $5000 on "supplies" (I've been fortunate to have a great district administration looking out for us) so I said let's see if we can get a small CNC to help build some small gear boxes, mounting plates and such. So we found the benchtop CNC mill by microkinetics. It may be different than the one you're referring to, but we've been pleased with it, it's just really slow, we usually only cut 0.05" at a pass through aluminum, and the Z-axis stepper motor is too weak to plunge cut most of the time, so we manually plunge the starting hole when needed, and then allow it to cut.
This year we got a CNC Jr. from CNCMasters - and so far it is worked out great, but we should have spent the extra money on the 220V Variable spindle speed option. We also found out that you must isolate your machines if you work in a tiny building like we do. We had our CNC Jr and Smithy both going at the same time and tripped the breaker and upon flipping the breaker back on, the CNC Jr. Contoller board fried. But CNC masters had it replaced within a week for $110 - critical because it was during January.
Hope this info was helpful.
Unread 20-06-2007, 15:29
Dick Linn's Avatar
no team (Synergy)
I would seriously check out the Tormach. And definitely ask around over at CNC Zone. Stay away from the "all-in-one" machines. If you can't afford a decent CNC, then get manual equipment and learn it the old-fashioned way.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 21-06-2007, 22:32
Alan Ing Alan Ing is offline
None #0368 (Kika Mana)
Alan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond repute
Definitely consider the Tormach. We were fortunate enough to pick one up in December.
You get a lot for the price. Check out the Manufacturing website videos to see its capabilities.
The 9.5" y-axis travel listed, is quite conservative. I think its closer to 10+ inches or so (I measured it, but forgot).
If your new to CNC like we are, don't expect to be blasting out parts. We got ours just before the season started and did not have enough time to learn to use it effectively. Every part we made on it could have been made with our manual mill. It is really convienient to drill bolt circles with.
Frankly, we really wanted another manual mill, but due to a technicality, it was easier to order this small cnc unit.
If you want to consider the Tormach, get the stand with coolant pump. Too much trouble to build your own. Does a good job containing coolant and chips.
On the down side, you cannot angle the head. Table is not hardened. We dropped a chain on it and put a few minor dings on the table. Steppers aren't as fast as servos, but its fast enough for us.
Consider what CAM program you will be using as it isn't included. We are using Inventor and an educational version of Edgecam.
What machines are you using? (CNC, lathes, mills, 3-in-1 machines?) MrB Technical Discussion 17 03-11-2006 11:55
lathes, what's best? ajlapp General Forum 16 27-08-2004 16:32
To CNC? Or not to CNC? phrontist General Forum 21 26-03-2004 13:45
Looking for a Smithy archiver 2000 3 23-06-2002 23:48
