Go to Post The very fact that parts are rumored to be being re-used may be sufficient reason for the rule-makers to change a rule to prevent the re-use of that very part (not that they would ever be that devious!) - dlavery [more]
Unread 10-06-2007, 17:33
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
where to get pneumatic parts cheap?
hi, i am trying to build a spudgun using pneumatics so i get more experience from them but could anyone give me some websites where i could get some pneumatic parts cheap? the ones ive been looking at are like 20 dollars per flow control switch for a half inch tube
thanks, vivek
"we don't build robots, we build people"
Unread 10-06-2007, 18:45
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: where to get pneumatic parts cheap?
if you're making a potato gun, may i suggest using hair spray and a BBQ starter?
Unread 10-06-2007, 19:32
vivek16's Avatar
AKA: vivek
yeah but the idea is to learn more about pneumatics.
Unread 10-06-2007, 19:35
tseres's Avatar
fair enough. i dont know the site, but Parker supplies the cylendars for FIRST, as well as Bimba
Unread 10-06-2007, 19:47
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
look on ebay....but beware, as usual.
The neat thing is that you can find all kinds of parts that you didn't know existed, then you can search specifically for what you want, once you discover what it really is.
300118790361 is an interesting item, might be too small though.
Unread 11-06-2007, 02:58
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Sounds like you need a sprinkler control valve. It's electromagnetic, and should not cost you more than $20.00 for one. Input/output is usually 1 inch or 3/4 inch, but you can easily reduce this to 1/2 inch. Check hardware stores in the irrigation department, or just ask for it.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 11-06-2007, 08:39
vivek16's Avatar
AKA: vivek
thanks for all the help guys! but fittingsdepot.com, allied electronics and clippard gave me all the parts i needed. im gonig to to get a plug valve from our local parker distributor later on in the day.
thanks, vivek
Unread 20-06-2007, 13:31
vivek16's Avatar
AKA: vivek
Does anyone know where I could get a manual quick release valve like the parker valve that you just turn the knob thing to release all the air?
thanks, vivek
Unread 20-06-2007, 14:05
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Check your local hardware store. They should have small ball valves in the plumbing section.
REVving up for a new season
FRC #2848 (All-sparks)
thanks, vivek
I think you are looking for a ball valve in which case home depot or lowes will have them.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 20-06-2007, 16:09
vivek16's Avatar
AKA: vivek
yeah but i also need to interface some 1/4" pneumatic tubing to that.
thanks, ill look at some hardware stores.
Where to get MK Batteries in LA cheap Kirk Technical Discussion 2 03-03-2007 09:33
A cheap resource for parts, (terminals, wire, & Bimba pistons $40.00) RudimentaryPeni General Forum 1 04-01-2007 14:23
Where to get 4.8-9.6v drill cheap sanddrag Motors 6 09-06-2005 01:28
Pneumatic parts archiver 2001 2 23-06-2002 23:04
Pneumatic Parts HK_SRT_LDR_A OCCRA 3 16-10-2001 06:15
