Go to Post This is the hint that never ends, yes it goes on and on my friend. Some people start guessing not knowing what it was, and they'll continue to guess forever just because... - JaneYoung [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 25-06-2007, 10:56
FRANK(WGH) FRANK(WGH) is offline
Webmaster - delphielite.com
AKA: Frank
FRC #0048 (Delphi E.L.I.T.E.)
Team Role: Webmaster
FRANK(WGH) will become famous soon enough
Send a message via AIM to FRANK(WGH)
Re: Dynamic Tables in PHP
Thanks for the fast reply.
I decided not to use a database quite yet because I haven't learned a lot about them, and every time I try to use databases, I end up failing for some reason and I can't troubleshoot because I have no idea what I'm looking at.
I've run into some trouble again with databases.
Could you show me a sample of the connection configuration you would use. I specified localhost as my server and then 127.0.0.1 and neither worked.
Also,
What does the database structure look like. I created a database with a table called picture. what columns do I need to have for your script to work.
I do want to learn from this, so I'm not asking you to write this all for me, but I need some examples to learn from.
Thanks again
Frank Bosak
Collegiate Mentor Association
Team 48 - Delphi E.L.I.T.E.
Online Engineering Tables SuperJake Math and Science 4 07-04-2005 14:07
Look Up Tables amateurrobotguy Programming 7 09-03-2005 00:14
Dynamic Linking with PHP plutonium83 Website Design/Showcase 6 12-01-2005 19:41
Large Lookup Tables Mr. Lim Programming 5 16-02-2004 21:30
Tables in pits? Rickertsen2 Regional Competitions 2 23-03-2003 12:42
