Go to Post I think I just found a way to replace our entire robot drive team! (no big deal, they are graduating anyway!) :D - dlavery [more]
Unread 29-06-2007, 10:32
barbarossa49au barbarossa49au is offline
barbarossa49au is an unknown quantity at this point
GNU Grub uninstall
Trying to delete Grub from a computer running Windows 2000. FDISK/MBR does not do the trick with this O/S. Can anyone advise the correct procedure?
Unread 29-06-2007, 11:32
notaPINKtruck's Avatar
notaPINKtruck notaPINKtruck is offline
AKA: Ryan Julian
FRC #0233 (The Pink Team)
notaPINKtruck is a splendid one to beholdnotaPINKtruck is a splendid one to beholdnotaPINKtruck is a splendid one to beholdnotaPINKtruck is a splendid one to beholdnotaPINKtruck is a splendid one to beholdnotaPINKtruck is a splendid one to beholdnotaPINKtruck is a splendid one to behold
Send a message via AIM to notaPINKtruck
Re: GNU Grub uninstall
Boot into a Windows 2000/XP Recovery Console (it's an option when you boot a setup CD of either). Use the commands FIXBOOT and FIXMBR.
That should do the trick.
Rockledge HS/Cocoa Beach HS & NASA Kennedy Space Center
Team 233: "The PINK Team"
Official Native Win32 version of GNU Make Astronouth7303 Programming 0 05-01-2007 00:59
GNU GRUB Question Raven_Writer IT / Communications 5 16-07-2004 21:38
