Go to Post Remember, however, that such software limitations in no way approximate the functionality of a multiple-speed, mechanical transmission. They're simply a convenient way of limiting your students' lead feet. - Madison [more]
Unread 30-06-2007, 15:42
Devo1098 Devo1098 is offline
FRC #1098
Devo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really nice
USB To Serial
Ive been trying to use a usb to serial adapter to program the robot, but its not working,
on ifi loader you have the option to use com port 1 - 12
under properties of my device it says Port_#0001.Hub_#0002
Any one know how to get it to work?
Devo
Unread 30-06-2007, 16:04
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Re: USB To Serial
What usb to serial are you using? For the vex adapter, I went into the device manager in windows. To get into the device manager, right click on my computer and go to the hardware tab and click the device manager tab. Go to the ports section, and see where your serial adapter is. Then go into IFI Loader and click the matching port. Make sure you have the correct drivers installed too.
Good Luck,
Malhon
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 30-06-2007, 16:06
Re: USB To Serial
Typically, those use either COM3 or COM4 selected from the IFI_Loader PortSettings pull-down.
Try each one by selecting it then trying to Download. Make sure the RC is set to program mode first.
Unread 30-06-2007, 19:51
foote stepped in
AKA: E. Foote
FRC #0868
Re: USB To Serial
I have one of those, it was COM4. Also, my laptop was funny about which usb drive it was plugged into (although it shouldn't have made any difference), caused much frustration to some people.
I remember that if you use hyper terminal, the device should show up there as one of the options to connect to. Hope that helps.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
USB-to-Serial Interface Alternatives Josh Adelson FIRST Tech Challenge 8 22-03-2006 09:40
usb to serial cable karinka13 Technical Discussion 4 10-02-2006 17:30
USB-Serial adapter Bill_Hancoc Chit-Chat 4 03-01-2006 07:18
USB to Serial adapter John Gutmann Programming 7 09-05-2005 01:34
USB to Serial Jack Programming 24 23-12-2002 14:21
