Go to Post Chances are it's an electrical or mechanical problem... - mechanicalbrain [more]
Unread 01-07-2007, 15:39
Re: C Programming Homework Help Needed
The function you are looking for is called "sprintf".
Use it just like you would use printf to print a float. The trick is that it throws it into a string, rather than at the console.
char * buffer = new char[10];
float f = 12.4;
sprintf(buffer,"%f",f);
I think... I don't have a C compiler in front of me.
Unread 01-07-2007, 20:48
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
Is there a header file you need to include?
I'm getting a 'no prototype for function' error for the sprintf function.
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 01-07-2007, 21:05
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
I believe you need to include stdio.h.
Unread 01-07-2007, 21:25
FiM Volunteer
That made that error go away but I still don't really understand how to use the function.
The first line:
is confusing me.
Unread 01-07-2007, 22:28
AKA: Dr. Brooks
no team (WRRF)
The first line:
is confusing me.
The use of the "new" operator is C++ speak, not C speak.
char buffer[10]; /* bigger than 10 is a good idea */
If a static or automatic array (depending on the location
of the declaration) is good enough, or
char *buffer;
buffer = malloc(10); /* again, bigger than 10 is a good idea */
to allocate the storage using the heap allocator in C.
Eugene
Unread 01-07-2007, 22:40
FiM Volunteer
I am using this code:
#include <stdio.h>
int main(void)
	char *buffer;
	float f = 12.4;
	return 0;
Attached is the compile errors I am getting.
Unread 01-07-2007, 22:46
AKA: Dr. Brooks
no team (WRRF)
#include <stdio.h>
int main(void)
	char *buffer;
	float f = 12.4;
	return 0;
malloc() is likely declared in stdlib.h
Unread 01-07-2007, 23:01
FiM Volunteer
It was. Thanks.
Now how can I use the char value?
I tried:
printf("%c", buffer);
But that printed out an an arrow pointing up.
Unread 01-07-2007, 23:11
AKA: Dr. Brooks
no team (WRRF)
It was. Thanks.
I tried:
The result of sprintf is a null, '\0', terminated string.
printf("%s", buffer);
printf("%c", buffer[0]);
would print the first char
Eugene
Unread 01-07-2007, 23:14
FiM Volunteer
Eugene
Thanks! I think that should do it for this week!
Unread 03-07-2007, 13:02
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
It was. Thanks.
I tried:
If you just want to print the value of the float, skip the sprintf() call and go straight to printf():
float f = 12.4;
printf("%f",f);
The *printf() family of functions (sprintf(), fprintf(), printf(), etc.) all work similarly. Becoming familiar with them will help.
If you ever have a simple question about a function, Google is your friend. (Just put in the function name or "C functionName".) Even Wikipedia has an article about most standard functions.
Unread 02-09-2007, 19:41
FiM Volunteer
This code is supposed to convert a base 10 number, 123, into binary and display the value. Somewhere in the conversion, the division loop stops before it should, for a reason that I cannot identify.
Output with some diagnostic print statements attached.
/* Patrick McCarthy */
#include <stdio.h>
#include <math.h>
void base_convert(int base);
void convert_to_binary(int base, int number);
void divide(int D, int N, int *pq, int *pr);
int main(void)
	int base;
	int base_error;
	/* Gets the base from user and validates the value */
	do{
		base_error = 0;
		/* Collects base value from user */
		printf("Please enter an integer between 2 and 10 =>");
		fflush(stdin);
		scanf("%d",&base);
		/* Validate entry */
		switch (base)
			case 2:
			case 3:
			case 4:
			case 5:
			case 6:
			case 7:
			case 8:
			case 9:
			case 10:
				break;
			default:
				base_error = 1;
				printf("Invalid entry\n");
	while(base_error);
	/* Finds base N value of NUMBER */
//	base_convert(base);
	/* Converts number to Binary */
	convert_to_binary(base, 123);
	return 0;
	int i;
	int new[3];
	int NUMBER[3];
	int answer;
	//The base 10 number to be converted
	NUMBER[0] = 3;
	NUMBER[1] = 2;
	NUMBER[2] = 1;
	for(i = 0; i < 3; i++)
		new[i] = ( NUMBER[i] * pow(base,i) );
		// Diagnostic
//		printf("i = %d; NUMBER[i] = %d; new[i] = %d\n", i, NUMBER[i], new[i]);
	answer = new[0] + new[1] + new[2];
	printf("%d%d%d(Base 10) = %d(Base %d)", NUMBER[2],NUMBER[1],NUMBER[0],answer, base);
	return;
	int j,h;
	int q[16];
	int r[16];
	q[0] = number;
	for(j = 1; q[j] >= 0; j++)
		printf("j=%d\n",j);
		divide(base, q[j-1], &q[j], &r[j]);
	for(h = j; h <= 0; h--)
		printf("%d", r[h]);
	int q,r;
	q = N / D;
	r = N % D;
	printf("Quotient: %d\nRemainder: %d\n\n", q,r);
	*pq = q;
	*pr = r;
Unread 02-09-2007, 20:04
A few notes to make your life easier:
The switch(base) structure is confusing. I suggest replacing it with something that more clearly states what you want. I'd recommend something like
if(base <2 || base > 10) { Error !!}
I do like your use of the do while. However, I'd rather it set base_error=0.
Your printf statement doesn't really tell the user what you are going to do with the number. Put a more informative request in there.
"Please enter the base of the number (between 2 and 10)"
Please comment what q and r are. They are probably quotient and remainder, but explicit = maintainable.
Okay, enough with the picky details. Pain in the patookus, but trust me, you'll thank me later.
To clarify divide, I've used pass by reference, rather than by pointer. Also, I've added some more debuggging!
void divide(int D, int N, int &q, int &r)
	q = N / D;
	r = N % D;
	printf("%d/%d :: Quotient: %d\nRemainder: %d\n\n", N,D,q,r);
_____________________________________
Thought of a few more helper functions.
int convertFromBaseToBinary(int base, char * number_string)
	int num=0;	//number converted from string
	for(;number_string;number_string++)	//Scroll through the letters, starting with the most significant digit
		num = num*base+charToNumber(*number_string)
	//num now holds the correct number
	return num;
int charToNumber(char a){
	return int(a-'0');
char numberToChar(int i){
	return char(i+'0');
EDIT 2
Just noticed another bug.
will never terminate. I think you want q[j]>0 or maybe even q[j-1]>0
Edit 3
And for more giggles, here is some Python
def convertToBase(num, base):
	s=[]
	while num is not 0:
		s=[num%base]+s
		num/=base
	return s
Unread 02-09-2007, 20:43
FiM Volunteer
I'm having a little bit of trouble now. See output.
#include <stdio.h>
#include <math.h>
void divide(int D, int N, int &q, int &r);
int main(void)
	int base;
	int base_error;
	do{
		base_error = 0;
		printf("Please enter the base of the number (between 2 and 10) =>");
		fflush(stdin);
		scanf("%d",&base);
			base_error = 1;
	while(base_error);
	return 0;
	int i;
	int new[3];
	int NUMBER[3];
	int answer;
	NUMBER[0] = 3;
	NUMBER[1] = 2;
	NUMBER[2] = 1;
		// Diagnostic
	return;
	int j,h;
	int q[16];
	int r[16];
	q[0] = number;
	for(j = 1; q[j]>0; j++)
		printf("j=%d\n",j);
		printf("%d", r[h]);
	int q,r;
	/* q is the quotient and r is the remainder */
	q = N / D;
	r = N % D;
Unread 02-09-2007, 20:54
You only half integrated my changes to divide.
q and r are coming in as references. You do not need to declare them again.
Also,
should read as
divide(base, q[j-1], q[j], r[j]);
I'm going to be offline for a while. Good luck!
programming help needed krunal Programming 3 29-01-2007 00:18
Help on a Homework Assignment. Pavan Dave General Forum 1 13-09-2006 14:20
HELP-URGENT PROGRAMMING HELP NEEDED Rohith Surampudi Lego Mindstorm Discussion 1 24-03-2006 23:05
URgent Programming Help needed rcubes85 Programming 4 15-02-2005 23:21
