Go to Post Trust me. I am a Clock after all. ;) - Elgin Clock [more]
Go Back   Chief Delphi > Other > VEX
Unread 29-06-2007, 23:23
ManicMechanic ManicMechanic is offline
AKA: Yolande
VRC #0438 (Metal Gear)
ManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond repute
Too many R/C commands in a loop?
The attached program uses 8 commands in a loop, with the first 4 allowing the left joystick in R/C to shift a holonomic drive up/down left/right, the last 4 allowing channel 5 to spin the bot. When I insert the first 4 commands in the loop, the bot shifts properly. The last 4 commands in the same loop (without the first 4) spins it properly. But all 8 commands in the loop causes the bot to go berserk. Does 8 commands force it to sample too frequently? And how do I work around the problem? When I insert 2 loops sequentially, it never makes it to the second, because the first condition is always true.
A secondary problem: how do I copy and paste text in EasyC? I had to do a screen shot to post the program.
Name:	holo program.JPG
He is no fool who gives what he cannot keep to gain that which he cannot lose. - Jim Elliot
Unread 02-07-2007, 00:52
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Too many R/C commands in a loop?
1) The second four commands are overriding the first four.
I wrote this code from memory, so if it isn't perfect don't yell at me.
#include "Main.h"
void main ( void )
      int x;
      int y;
      int r;
      int nw;
      int ne;
      int sw;
      int se;
      //Get inputs
      x = GetRxInput ( 1 , 1 ) ;
      y = GetRxInput ( 1 , 2 ) ;
      r = GetRxInput ( 1 , 3 ) ;
      // convert the inputs so 0 is neutral.
      x -= 127 ;
      y -= 127 ;
      r -= 127 ;
      // compute outputs
      nw = x + y - r ;
      se = x + y + r ;
      ne = x - y - r ;
      sw = x - y + r ;
      //Set outputs
      SetPWM ( 1 , nw + 127 ) ;
      SetPWM ( 2 , ne + 127 ) ;
      SetPWM ( 3 , sw + 127 ) ;
      SetPWM ( 4 , se + 127 ) ;
You should also add code so that you don't try to send the motors values less than 0 or over 255.
2) This is how you get text from EasyC.
a. Select the Project tab under the list of functions.
b. Right click on the function you want to get text from, and click Open C file.
c. Highlight the code, right click, select Copy OR Ctrl+C.
NOTE: You should post programming questions in the programming section of the forum, even if your questions are Vex specific.
Eric Haskins KC9JVH
Too many photos with CD-Media? miketwalker General Forum 23 31-05-2006 16:16
pic: TOO MANY TETRAS!!!! Ali Ahmed Extra Discussion 12 22-01-2005 10:06
Too Many People In The Pit Jay05 General Forum 7 09-03-2003 10:46
