Go to Post People will only work toward common goals when they are part of the goal-setting process. - GaryVoshol [more]
Unread 02-07-2007, 11:05
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: Correlation Finding Software?
Originally Posted by artdutra04 View Post
You can do this in Excel...
In excel there are functions called SLOPE and INT that will calculate the best fit linear equation values (y=SLOPE*x+INT) from an x & y array of values. There are also formulas for exponential distributions.
Additionally, if you are still looking for the which best fit eqn to use try plotting the arrays on an XY graph. From the graph select a point from the dataset, right click and select the trendline option. This will allow you select from a variety of eqn forms (polynomial, log, exp...) and well as display the equation for the best fit curve and the R^2 value. You can use the equation for secondary processing, but it does introduce a minor amount of manual processing.
Mark
Brick walls are for other people. - Randy Pausch
Finding range DanDon Programming 11 10-01-2006 22:58
Finding color brownster Programming 1 20-02-2005 03:23
Finding sponsorship Lisa Perez Team Organization 12 17-10-2004 16:43
Finding New People Josh547 Chit-Chat 9 17-01-2004 11:56
Finding helping hands Anne Lam College Teams 6 23-07-2003 21:57
