Go to Post If I'm going to mentor someone, I'm going to be involved in their life as a positive force. - Mechvet [more]
Unread 30-07-2005, 05:46
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
HomeMade Motor Controllers
I know that the Victor series motor controller is complex, but i wanted to venture into the unknown, and make something i haven't made yet(that being hard with how much i have done) and i was wondering what kinda of transistors were used in the Victors to obtain such high current potential, and if anyone knew a function control flow chart for it: IE does it amplify the pwm signal then use it or just use it straight from the source
The transistors used in it, are the FETs or MOSFETs, i was thinking one of those since they do not hold their state for long and need to be refreshed in a cycle (such as in DRAM)?
for the transistors to withstand the curent are they in series?
and for my own should i use a heat sink and a fan or just a fan, beacause if possible i would like to get the TO-220 package so it has some built in surface area for power diapation
and my PCB how do i make a PCB to stand up to about 50 amps or more?
thanks
-john-
PS- I DO NOT INTEND TO USE THESE INCOMPETITION OR FOR ANY RELATES PURPOSES, I INTEND TO USE THEM FOR MY OWN PERSONAL USE!!! FOR THAT REASON I DONT CARE WHAT FIRST'S RULES ARE!!!!
Unread 30-07-2005, 08:06
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Re: HomeMade Motor Controllers
a great place to learn, actually is to read a lot about combat robots. this guy eric, who participates in the northeast robot combat events is very saavy in electronics. heck, he even BUILT his own brushless motor and made the can of it as his spinning weapon. if you would like to browse websites, etc, here are a few.
www.robotcombat.com
www.nerc.us (theres a link to delphi forums, thats where you may find loads of indo)
www.teamdelta.com
these are a few, hope you find something intresting!
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 30-07-2005, 11:04
The circuit inside the Victor speed controllers is called a H-Bridge. You can Google H-Bridge and find a multitude of schematics and explanations.
If you're really industrious, I posted a link a while ago that listed the exact type of FETs used in the Victor speed controller. Realize, however, the Victor uses 9 FETs, while most H-Bridge implementations use 4. That's why the Victors can handle such a high current. However, it gets very dangerous to handle such a high current.
What are you building this on? Most breadboards use wire in the range of 22awg which is rated for less then an amp.
The Victor does amplify and condition the incoming PWM signal because the incoming signal is pulses between 1 and 2ms every 20ms. The FETs need pulses ranging from 0 to 100% duty cycle. You'll probably find out more about that from other sites about h-bridges and motor controllers.
Normally I'd suggest buying an IC with the H-Bridge integrated, but I have a feeling you'll blow off that suggestion.
Unread 30-07-2005, 11:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You might want to check out this place http://www.robot-power.com/ and their OSMC project. Also, they have some parts (like the board) in their web store. I'm betting since it is Open Source, if you e-mail them they'll be able to answer any questions you have about it.
Unread 30-07-2005, 23:27
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
what is the main advantage of using FETs
what is the difference between FETs and MOSFETs
Unread 31-07-2005, 12:37
Gdeaver Gdeaver is offline
FRC #1640
For info on FETS, IRC a manufacturer, has allot of info on their web site.
http://www.irf.com
Check this site out for a speed controller primer.
http://homepages.which.net/~paul.hil...ntrollers.html
There are single chip speed controller chips that will work for small motors and stepper motors. They can all so drive FETS. The following link shows the hardware and software control of one of these chips.
http://kronosrobotics.com/an101/DAN101.shtml
Research to understand speed controls is OK, But as far as making one. Why reinvent the wheel when hobby RC car controllers are quit cheap. Learning how to use speed controllers and stepper drivers in control strategies may be a better place to focus your energies.
Unread 31-07-2005, 12:41
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
http://en.wikipedia.org/wiki/Field_effect_transistor
A MOSFET is a kind of FET. I'm not well versed in transistor theory, so I'm not sure what you gain my using other FETs over MOSFETS. But the reason MOSFETs are used as opposed to normal bipolar transistors is that you can parallel them. Let's say I have a MOSFET and a bipolar that can handle 10A each. For my device to handle 50A, I would need to parallel 5 of them. Paralleling the MOSFETs is fine becuase when they heat up, their resistance increases. Let's say that MOSFET 1 starts to heat up. Its resistance increases and it carries less current. The other 4 would pick up the slack. As 1 starts to cool down, it will carry more current and another would get a break. Of course, it isn't that linear and it happens very fast, but I think it gives you the idea. Bipolars, on the other hand, will all heat up together. When one of them finally explodes, the others are left with distributing the full 50A load and another will blow even faster than the first one. They will all cascade until you have nothing left but a smoking pile of transistors.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 31-07-2005, 20:56
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
so a MOSFET is like the same thing but only, i guess you would say safer?
Unread 31-07-2005, 21:31
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
what kind of chips or what different chips can I use to interpret the pwm signal for forward and reverse and the correct duty cycles and all that?
Unread 31-07-2005, 22:49
Electrical Engineer
AKA: Phil Baltar
FRC #1351
Not exactly, MOSFETs and bipolars each have their uses. They work in slightly differnet ways that would suite different applications. In some applications, you would need to use bipolars because MOSFETs won't work and vice versa. For a high powered motor controller, I think the MOSFETs would be best.
It would depend on what your final application would be. I don't remember the manufaturer/part# off the top of my head, but there's a chip to control a MOSFET h-bridge (there's some subtle timing/voltage issues that need to be taken care of). That specific chip doesn't do any PWM though. For that, you'd probably have to use a PIC (possibly in conjunction with this h-bridge controller). I don't know of any commercial ICs that handle hobby radio PWM to motor control PWM. If you can't find an existing program for a PIC, you'd probably have to write it yourself.
Version: 3.12
Unread 04-07-2007, 19:15
Generalx5's Avatar
Generalx5 Generalx5 is offline
Hard Core Inventor
AKA: Jun(John) Zheng
FRC #1346 (Trobotics)
Team Role: Student
Generalx5 will become famous soon enough
Cool Re: HomeMade Motor Controllers
All I remember is that these Metal Oxide Semiconductor field effect transistors in those victors are linked together in parallel, they are high current transistors that either has an N substrate or a P substrate. PMOS or NMOS, I also know that they require something called a MOSFET Driver that delivers short bursts of high current 1- 3 amp of 5- 22 volts to the gates of the MOSFETS, these drivers can be found either inverted or non-inverted so that a +5 could either indicate MOSFET conduct or not conduct. There is a helpful guide on the IRF website that explains how to pick your MOSFET and match it with a proper MOS Driver. Its really complicated...
examples of MOSFET DRivers are the ones from Microchip.com, TC4426 (improved version of TC426), TC426. The two listed are dual drivers, they can drive 2 different signals at one time. You can also find single drivers and Quad drivers as well. These drivers tipically require about two miliamps of current in their source. Its important to have a capacitor at their drain and source terminals. The MOSFETs we see in the Victors each can handle about 20 - 30amps? (ballpark figure...maybe more) with it hooked up in parallel, they are able to source large amounts of current.
It is important that you look at the white pages on the MOSFET specific to your project, they will tell you how much current it is able to handle under what temperatures, proper air cooling with sinks may be needed. also as mentioned above, with the rise in die temp, the resistance also increases, but this shouldnt be a problem if you are using a MOSFET driver. Hope that helps.
Unread 04-07-2007, 22:20
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Well in reality the only danger that you have at such low voltages is from stuff exploding. You really can't be harmed from shock but even at 36 volts the amount of shrapnel produced by the FETs is amazing when they fail.
Your forgetting about IGBTs which is an odd mix between an MOSFET and a BJT. Essentially, it turns on like a MOSFET but handles current like a BJT. Also Power MOSFETs are different from regular MOSFETs because there is a diode included . If you look at a circuit symbol for a power MOSFET you will see that diode include.
It's complicated to the point where I really wouldn't recommend such a project if your not out of in college. If your PWM frequency is high enough you may run into transmission line problems. You start running into weird parasitic capacitances/resistances/inductances that cause the gates to ring which will result in the FETs not turning on and off cleanly. The high side drivers can actually latch on which results in the FETs staying on when they shouldn't be. I spent the last four months with people much smarter than myself trying to do essentially what you want to do but we really had problems.
Unread 05-07-2007, 00:50
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
I think you might have meant 12 FETs. An odd number of MOSFETs in an H-bridge doesn't work so well.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 05-07-2007, 08:17
Wow,
Talk about reviving old threads!
The device used in the Victor is an International Rectifier IRL3103. What makes a MOSFET a better choice for this service is the very low "ON" resistance and the ability to switch inductive loads. (This device is actually a HEXFET, a particular processs for the silicon layers of the device) Since the series resistance is so low (12mohm per device) large currents do not cause the internal temps to rise. This device does contain an internal diode so it's ability to be used as an amplifier is limited. These diodes are what conduct to turn lights on in the robot when it is pushed with the power off. Current generated in the motors pass through the diodes back to the robot electrical distro. The "H" bridge forms a very nice bridge rectifier when fed in reverse from the motor.
An exploding FET has little to do with applied voltage and everything to do with internal heat. A rapid release of magic smoke is what blows the case apart.
The IGBT (insulated gate, bipolar transistor) shares some charachterisitics of the MOSFET. i.e. it is a voltage driven device (very low drive current) but it does not have the low "ON" resistance needed for this application.
The output switching frequency of the Victor is a tradeoff that allows better speed control for a series of motors that share similar brush/commutator spacing specifications. As a brush DC motor rotates, the brushes switch different windings to the power source. For best control the switched input current should be optimized to this motor switching so that the motor still has good start torgue at low speeds and good speed control at high speeds. Very short pulses vs brush/commutator spacing will not allow the motor to start under load and long pulses will not give any control at high motor RPM. The 884 Victors have a designed output of 120 Hz for this reason. You will note that the ouptut frequency is not the same as the input PWM signal. The internal controller translates the 0-255 modulated PWM signal to a 94 step output signal and provides direction switching as well. Remember that an H bridge operates by turning on only two of the legs at a time for direction control and braking. There is a lot of circuitry inside an 884.
Please be aware that insulated gate and MOS devices still are subject to static induced failures and require some special handling. They are not nearly as sensitive as when first introduced but...
Unread 09-07-2007, 21:38
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Wow, Talk about reviving old threads. Yea. Well I never actually had the money to play with anything. So No need to post too much info except for the fact that it may help someone else.
I am more into microcontrollers now.
-John
homemade speed controlllers (for school project) Denman Electrical 26 18-04-2005 11:07
Homemade Robotics Clothes Jill1022 General Forum 9 28-03-2005 14:57
Globe Motor archiver 2000 4 24-06-2002 00:15
