Go to Post At the end of the day, and this is where many may disagree, it's about what is learnt and not about who wins. - popnbrown [more]
Unread 07-07-2007, 14:06
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: pic: DeWalt drive base: side module
that's pretty cool....I'm curious though....what kind of interface shaft do you have to connect to the end of the dewalt for the direct drive setup?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 07-07-2007, 18:22
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
The shafts that go between the 2 red plates and hold the wheels are .75:" thick. In the end of those there is a .5" threaded hole. The DeWalt will screw into the end of the shaft. Then i will drill a hole through both shafts and put a pin through. Hopefully this will be solid and strong.
Unread 07-07-2007, 21:26
newton418's Avatar
newton418 newton418 is offline
AKA: Ryan Newton
FRC #0418 (Purple Haze)
Team Role: Driver
newton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to all
Originally Posted by fimmel View Post
also in team 885's experience the dewalts dont shift at exactly the same time.. this would cause binding as far as i know. out solution was to only use 1 dewalt/cim per side.
...just a thought
...forest
Though I'm sure there are minor differences in the shifting times, we've never had a problem running 2 DeWalts on one side, connected by chain. Perhaps we weren't pushing them as much, it's definitely doable to have 2 DeWalts on one side of a drive train.
Team 418 Purple Haze
http://www.lasarobotics.org/
Unread 07-07-2007, 22:44
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
its cool to hear someone who has done this successfully.... we never did try linking 2 together but we were cautious. ill tell our head engineer about this since it makes my job as a part designer easier.
...forest
Unread 09-07-2007, 15:43
AdamHeard's Avatar
Lead Mentor
3/4" diamater shafts will definately be strong enough; especially if they are steel. Depending on the size of the pin you're putting through, aluminum should be just fine. Either way, 3/4" is kind of heavy though. I guess you don't have much of a choice w/ the current interface with the dewalts though.
Unread 09-07-2007, 16:02
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
--Madison--
...down at the Ozdust!
Unread 09-07-2007, 18:36
REVving up for a new season
FRC #2848 (All-sparks)
[note] this is not picking on adam I am just using it as an example [/note]
There are alot of things that go in to the"strength" of a material in an application. Just saying that it will be strong enough shouldn't really cut it when contributing to a design.
As an example when you are talking about strength it is obvious that you are referring to not failing during application, but in what ways is the part strong enough. Are you concerned with the torsional strength to make sure the shaft wont twist off? What about the bending stresses of this kind of loading And don't forget to take into account the stress concentrations caused by the pin slot and the fatigue strength due to alternating loading...What about the shear strength of the pin itself?
I guess my point is there is alot more that should go into the design of a system like this, and just making wild guesses could cost you in the end. If you under design something you can get a failure and if you over design you have wasted weight and real estate for this mechanism.
Now I realize that 95% of the teams out there probably don't do/ know how to do any of this math and just throw stuff together (I know I have fallen to the same fate from time to time) but in the off season when we have plenty of time for this kind of top level design. I urge everyone to open a book or ask someone who knows for help on these problems rather then taking the "backyard engineering" approach and just winging it. Same goes for those offering suggestions on design to be able to backup your suggestions with some theory. Remember there are teams who live and die by the advice given on these boards and you want to make sure that they are given correct information.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 09-07-2007, 19:11
AdamHeard's Avatar
Lead Mentor
Looking at the amount of torsion put into the shaft (I just ran some similar calcs yesterday for a 1/2" shaft ) that shouldn't be the problem, What I was reffering to was that the point of failure will probably depend on the pin (either the pin itself, or the shaft where it engages the pin).
With so much time on your hands, and since you already modelled it anyway, you my as well learn to use the stress analysis built into inventor to check your it. I've been using this all season on critical parts and it has never failed me (remember to build in a safety margin).
pic: 25's drive module Billfred Extra Discussion 17 06-06-2007 10:35
pic: 114 drive module design CraigHickman Extra Discussion 3 06-12-2006 21:59
pic: Dual sprocket Dewalt drive Andy Brockway Extra Discussion 4 05-12-2006 08:05
pic: Team 710 Drive module CD47-Bot Robot Showcase 20 04-03-2004 01:21
pic: Dual-Speed Drive Module CD47-Bot Extra Discussion 3 07-11-2003 13:45
