Go to Post Please ask a specific question if you want a specific answer. We are not psychic; we can not read your mind. - Astronouth7303 [more]
Unread 07-07-2007, 12:11
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
pic: DeWalt drive base
Unread 07-07-2007, 12:25
run the trap!!!
Team Role: Human Player
Re: pic: DeWalt drive base
Correct me if I'm wrong, but isn't it risky to use two shifters on the same side?
Suppose one of the servos stops shifting... Then you'll have two gearboxes chained together running at different speeds. The DeWalts will strip themselves, and you'll lose half your drive train.
Yes, it is an unlikely scenario. But its the kind of disaster that could ruin your day.
-Philip J. Fry
Unread 07-07-2007, 12:59
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
and why 8 40 amp fuses and 10 victors
Unread 07-07-2007, 14:42
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
It wouldn't be quite as risky if you didn't chain all 6 wheels together...just connecting the middle wheels to the back wheels...I would probably try that first and see how it drives before added a second set of chains. On the other hand, I have seen other teams like 418 use this configuration successfully with no shifting problems
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 07-07-2007, 16:16
CraigHickman
Posts: n/a
I'm intrigued by your frame design. What made you do the two triangles?
This would make manufacturing it take a bit longer, as well as welding it slightly more difficult. I personally would have just run the bars straight across, which would have also given more area to mount to for other mechanisms.
Looks like and interesting idea, good luck with it!
Unread 07-07-2007, 20:46
AKA: David Bell
This is a possibility. If the servos do not shaft at the same time one or more of the following might happen:
The Dewalts might break (they are very strong)
the CIM might burn out (unlikely)
the sprockets might break
the chain might break
If this happens it will be bad.
The plan is to have another 1 or 2 spare side modules ready to go on. It will be able to come on and off in just a few minutes, to we will be ready to drive again in the next match.
If the drivers realize that this is happening during the match they might be able to shift one dewalt into "neutral" (between 1 and 2 or between 2 and 3) and use the other one.
I really don't know how likely this is.
Originally posted by richardmcc2 It wouldn't be quite as risky if you didn't chain all 6 wheels together...just connecting the middle wheels to the back wheels...I would probably try that first and see how it drives before added a second set of chains. On the other hand, I have seen other teams like 418 use this configuration successfully with no shifting problems
This might help. If the wheels didn't shift at the same time the wheels would slip a bit, but still much less harmful.
I chained them all together because that way each of the 6 wheels has the power of 2 CIMs. If you did what you are saying you would not have as much power to each wheel itself.
I haven't finished the electronics yet.
Yeah, the triangles do add some complexity. The reason i didn't put one bar across is because that way there is a rectangle. I usually try to use triangles when possible because they are stronger in general. Your idea may be better though, I'll think about it.....
DB
Unread 07-07-2007, 21:44
newton418's Avatar
newton418 newton418 is offline
AKA: Ryan Newton
FRC #0418 (Purple Haze)
Team Role: Driver
newton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to all
Slick design, I'd love to see pictures of the real version, and perhaps some battle reports, so make sure to keep us updated after next season.
418 has worked with a similar design for the last 3 years, and the only time we've had a shifting problem is when the backup battery wasn't charged... so none of the DeWalts shifted.
IF one of them didn't shift, then the DeWalt that didn't shift would just be powered by the one that did, so it shouldn't create any significant damage (though it will be quite obvious something is wrong). If this happened, I'm sure the driver would just shift back and stick with that gear for the rest of the match. But again, this is a very unlikely scenario if you follow the whitepaper word for word and your code does what you want it to.
We did this our first year with the DeWalts, and learned a valuable lesson.
If you have one DeWalt powering 2 wheels, and another powering 1 wheel, you will have a significant power bias. Think of it this way, you get into a pushing match, your back wheels have their own CIM-DeWalt to themselves, and the middle and front wheels share another. While the back DeWalt easily delivers enough torque to slip your back wheels (creating significant wear on the thread, and reducing your traction) your other DeWalt struggles to provide enough torque to the the middle and front wheels. I'm sure you COULD distribute the weight such that the traction of the back wheels is the same as the combine traction of the middle and front wheels, but that seems unnecessarily constraining.
Another advantage is that if one of your back wheels isn't contacting the ground, the wheels that are contacting the ground still have the power of both CIM-DeWalt assemblies. This might seem like an unlikely scenario, but if you lower your center wheels (as most teams with 6 wheel drive do), and your center of mass changes (you pick up a heavy game piece, for instance) then before you realize it you're driving around on your center and front wheels... and half your power is uselessly spinning wheels that aren't contacting anything.
Team 418 Purple Haze
http://www.lasarobotics.org/
Unread 08-07-2007, 09:51
ctorloey ctorloey is offline
AKA: Dave Luongo
FRC #1153 (Roborebels)
ctorloey has a spectacular aura aboutctorloey has a spectacular aura about
This is a very cool, interesting design.
Do the Dewalts work good on your robot?
Was it hard to make the Dewalts and put them on?
Unread 08-07-2007, 12:48
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
How strong does this frame have to be for a FIRST Competition?
1/8" wall box tubing is very strong. A rectangle would work just fine. You've seen our robot drivebase this year, right? All rectangles and we never had any problems with it bended (even when people stood on it for various reasons).
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 11-09-2007, 21:55
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
That CAD looks amazing, nice work!
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 11-09-2007, 22:18
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
We haven't built this design - it's just a concept at this point. I'm not even completely sure it's possible to do (we may not be able to fit the third stage sun gear onto the CIM).
It took a fair bit of work to modify the DeWalts, but it was still less than any other 3-speed transmissions I know of and that we were capable of making with our limited resources.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 11-09-2007, 22:57
AdamHeard's Avatar
Lead Mentor
If you can't keep that stage, it wouldn't be too much extra work to move each dewalt inward, and have a sprocket reduction to the outer wheel. Then keep the center wheel connected in the same fashion.
Keep refining this until it is 100% ready for production, it will save your team a lot of time.
Unread 12-09-2007, 11:28
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
I'm not a big time drivetrain guy... but can a DeWalt transmission take the torque of two CIM motors? Perhaps you could combine their torque before going in to the transmission?
Or, to avoid the 'losing half the transmission and stripping them out' problem if one shifts and the other doesnt (or other reasons why one might sease) can't you just turn the torque clutch down on the drill to a reasonable number so that in case you start to backdrive the transmission too hard it just slips? I don't know how much torque the clutches go up to in those things before they go direct drive, just a thought.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 12-09-2007, 12:42
AdamHeard's Avatar
Lead Mentor
-q
118 Ran four small CIMs and two FPs into one dewalt this season.
Unread 12-09-2007, 13:00
newton418's Avatar
AKA: Ryan Newton
Team Role: Driver
I got to talk to some of the guys from 118 at LSR last season. They told me they'd had some problems with the gears in the DeWalt shattering, but I don't know exactly why this occured, or how frequent it was. Also, I remember them having several backup V6's. Nonetheless, they definitely proved that it can be done. Hopefully one of the guys that worked on the '07 118 drive train could fill us in on what they found out about the DeWalts.
-q
The DeWalts have been shown to handle the torque of two CIMs, but since only a few teams have done it, we don't have much information on how well they hold up. So many teams have followed the whitepaper and have never touched their DeWalts after that, and that reliability is part of what makes the DeWalts so valuable. Also, in dbell's design he's keeping the first stage of planetary gears, so there's already 3 times more torque on the transmission than what most people have used.
As for the torque clutch, it's typically removed with the CIM configuration, since we remove the first stage of planetary gears. Since this design is keeping those, I'm not sure if he's going to keep the clutch or not. Either way, in a high torque application (like the drive train), you probably wouldn't want to mechanically limit your power unless you really knew what you were doing.
dbell - are you planning on keeping the clutches? If so, you should read this: http://www.chiefdelphi.com/media/papers/1680. They kept the clutch in and found that it bent after a couple of matches, causing them to service the transmission frequently. If you aren't going to keep them, how are you going to keep the first ring gear in place?
pic: DeWalt drive base: side module dbell Extra Discussion 22 09-07-2007 19:11
pic: 1270's 8 wheel drive base redbarron Robot Showcase 9 12-02-2007 06:15
pic: Dual sprocket Dewalt drive Andy Brockway Extra Discussion 4 05-12-2006 08:05
pic: 195 Drive Base Tom Bottiglieri Robot Showcase 24 16-02-2006 12:50
pic: 1083 drive base CD47-Bot Robot Showcase 11 24-02-2004 14:04
