Go to Post I am alive today because I can't hold onto things. - Al Skierkiewicz [more]
Unread 08-07-2007, 11:31
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: Private bot - which PIC microcontroller?
Soooo....the serial cable si the only way to program it. Check it out.
No it isn't the only way. Look at the documentation again for the Butterfly. You can either program it using an ISP or a JTAG programmer. High voltage parallel programing is also supported but I have no idea why anyone would want to go that route unless somehow you screw up the fuse settings. Some assembly is required though because all of the ports are missing the header pins. I've used JTAG to program microcontrollers before. It's so nice seeing the program run and watching the registers change on the computer.
The stk and dragon are nice, but they are nor rally made to be put onto a robot. They are good to use as a ISP programmer if you have a seperate board with ISP headers, or if you have a chip that needs to be flashed then put into a socket somewhere. But I have found that with my STK since it has no holes and no other good way to mount it anwhere that I use it strictly for a dev. board.
I didn't actually say it should be placed on a robot. The dragon is just a bare bone pcboard with no way of mounting anything to it without some more assembly.
The arduino is nice. It is basically the BASIC Stamp of the AVR world. I looks like you can only program it using the "arduino language" which to me is not good. It is better to learn how to do it right the first time. I also can't find a price for it.
http://www.sparkfun.com/commerce/pro...oducts_id=8164
pic: Team 241: This Years Bot Lifting Last Years Bot Dantvman27 Robot Showcase 3 21-02-2007 07:04
Embedded Microcontroller major? John Gutmann Career 5 27-07-2006 23:49
Propeller Microcontroller Adam Y. Electrical 4 20-04-2006 13:27
217 Vs. 229 - Which Bot is Prettier? Swan217 General Forum 73 02-12-2005 13:30
microcontroller selection¿ Rickertsen2 Programming 11 25-05-2003 10:52
