Go to Post For FIRST robots, the phenomena listed above just do not apply. - Paul Copioli [more]
Unread 08-07-2007, 18:41
ManicMechanic ManicMechanic is offline
AKA: Yolande
VRC #0438 (Metal Gear)
ManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond repute
Re: Vex Programming Question
Originally Posted by 1885.Blake View Post
KingofI337 says below (thank you King) that older versions of EasyC had a hidden linkage between PWM Control and whether or not the microcontroller (plus the implied receiver...) detected a valid signal from a transmitter. He says this is gone from more recent Vex EasyC versions.
So, for purely autonomous operation (no Transmitter needed) I think you remove all PWM Control commands and replace them with Motor/Servo Module commands.
We're using the EasyC v2.0 upgrade, and we're not able to run autonomous programs with motor module commands unless we turn on the transmitter. I don't know if purchasing v2.0 from scratch produces better results.
He is no fool who gives what he cannot keep to gain that which he cannot lose. - Jim Elliot
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
VEX programming Gene F Programming 14 08-08-2006 22:21
Programming VEX Controller HRobotics Programming 4 21-03-2006 23:25
Vex like programming? Morenoh149 Programming 2 09-07-2005 22:32
Vex Programming foobert FIRST Tech Challenge 3 24-06-2005 01:09
