Re: Vista - Why so many flavors?
I have been using Windows Vista since RC1 came out early fall last year. All I can say is that I really like it. Sure there are some shortcomings right now and the hardware requirements are a tad high, but if you have the hardware and time, then I would fully recommend it to anybody. Let me tell you the story of my laptop:
I purchased my laptop around March 2006 after a water accident occurred with my last laptop. It came configured with the following hardware:
I tried linux, but it was too much of a hassle to configure and to use all my programs. I tried Windows 98 Yea... didn't go so well. Then I found Windows Vista Beta2. I installed it, liked the GUI, but it was way way too slow with all of the debugging software running and with the bugs left. So I went back to XP for a while.So I believe in September they released Windows Vista RC1. I signed up for testing, got a spot, and installed it on my laptop. All I have to say is Wow! It was much improved from Beta2. I believe by this time they had gotten rid of most of the debugging problems. After it installed everything worked great. I later upgraded to RC2 to get some more features and bug fixes, and it worked great as well. Dell started to distribute beta drivers when I had RC2 installed. I had RC2 until February when I bought Windows Vista Home Premium. When I bought Vista, nothing really changed. They included the sounds and a few other features, but it was basically the same Vista I had become accustomed to. As far as compatibility, I haven't had too much trouble. I've had drivers since I installed Vista RC1. Some drivers have been shaky such as my wireless driver. My wireless card would randomly shut off for no reason, and I would have to restart my laptop to fix it, but I later found that it was because the newer drivers had a bug that would shut them off. I went back to the default Vista drivers and fixed that problem. I've only experienced the BSOD twice with Vista, once was due to a bad driver for my Dazzle video converter, and again due to my hard drive being corrupt. The UI is the best thing about Vista. It's much more responsive than XP used to be, the graphics are awesome, and they have many innovative features such as the individual volume controls for every program that makes a sound and the quick search feature in the start menu, which is my favorite feature. For a laptop, power usage is a critical problem. With XP I would only get 4 hours of battery running time. With Vista, I can control more aspects of my system and can squeeze out 5 hours of running time. Gaming may also be a concern for anybody on the Delphi community. I play HL2, HL, Dod with ease. The Sims2 also works fine. Basically from what I've seen, games will play as good as they do on XP or even better. Now... some OpenGL things are messed up. Basically, Vista was going to drop all OpenGL support, but they later added a converter to use DirectX10 for OpenGL, which causes it to be slower than normal. As far as program compatibility, I haven't run into any major problems. If I do run into a problem, I can usually select a compatibility mode that works. I have Photoshop Elements 5 installed and running good, Dreamweaver MX running, Microsoft Office 2003, Autocad 2006, along with other programs that may be used by this community. All of those programs work with Vista without any problem. Vista includes a performance report that comes in handy if your PC starts to run slow. All I do is open it up, and see what is causing my problems. Vista basically logs everything that happens on the computer, the boot up, while running, and shutting down. Right now it shows that my video drivers are conflicting with resuming from standby. It took about 25 minutes to install on my laptop. It takes about 40 seconds for my laptop to boot up to a point where it is usable and about 1 and a half minutes to shutdown. The Gadgets are pretty neat as well. Most of them are 3rd party and there are already about two hundred available. I usually don't use them because they get in my way, but lately I have been using them. I can't really think of any consequences of using Vista that you cannot get around. |
Just to set the record straight, my system specs are as followed...
3.06g P4 w. ht 200gig sata hard drive 512 mb of ram onboard video Vista home premium runs fine on these settings...yea sometimes it gets laggy, but I can game AND run Inventor 2008 on it. |
I bought this computer for a graduation present to me.
* Dell Inspiron E1505 * Intel Core Duo 1.66Ghz * 1GB RAM * 80GB Hard Drive * ATI Mobility Radeon X1300 * Intel PROset wireless 3945ABG * Windows Vista Home Premium I heard all the rumors not to buy vista because it still has "new program bugs" that need to be fixed, it will make your life harder, and it will crash every other hour. I haven't come across any of these problems. Im on it at least 6 hours a day, running it to the max. I love it. It runs smoother then XP, it looks nicer and is much easier to do things. The only problem is that not many 3D design programs won't be compatible until 08. SO here i am waiting till 08. But if your looking to get Vista you need to make sure that you have at least 1 gig of memory and a decent graphics card. With out these it WILL be hard to run vista. But before you buy vista read the box it explains all the do's and don'ts for running it. Hope this helped Jacob |
| Why is it that not many girls are into robotics? | busterblade16 | General Forum | 115 | 23-04-2009 21:17 |
| why sooo many bad robots in 07 | nuggetsyl | General Forum | 84 | 31-03-2007 10:37 |
| Vista compatibility? | EHaskins | Programming | 29 | 19-03-2007 11:22 |
| Windows Vista | ThomasP | Chit-Chat | 15 | 01-02-2007 07:16 |
| Windows vista!!! | [527]phil | General Forum | 27 | 25-07-2005 17:01 |
