Re: what motor did you use(arm)
Gael Force used two FP motors this year, one for the lift and one for the extension. Both powered a ball-screw through repackaged FP trannies. The extension simply slide back and forth on bearings while the lift worked through a sliding four bar linkage.
| What IDE DID you use? | EHaskins | Programming | 15 | 22-02-2007 12:58 |
| What programming environment did you use? | StevenB | Programming | 10 | 18-03-2006 09:32 |
| Drivetrain, what did you use? | maclaren | Technical Discussion | 42 | 15-02-2004 21:09 |
| What modeling program did you use? | archiver | 2000 | 5 | 23-06-2002 23:24 |
