Go to Post It doesn't seem hard, but it is. You can do it with enough time, dedication, and skill, but that doesn't stop it from being hard. - lemiant [more]
Unread 12-07-2007, 09:16
drosophyllum drosophyllum is offline
FRC #0545
drosophyllum has a spectacular aura aboutdrosophyllum has a spectacular aura aboutdrosophyllum has a spectacular aura about
what motor did you use(arm)
Hello, im wondering what motor your teams used for the arm, the cim or the window motor.
Unread 12-07-2007, 09:26
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Re: what motor did you use(arm)
648 used the fisher price motor. It turned an arm, which was connected to another rod fixed to the arm. When the motor turned, the first arm raised the second, raising the arm, pretty much a large cam system. The arm had a telescoping feature driven by the banebots motor. We used the four small CIMS to power the drive system, and the window motors to turn the wheels in our swerve drive.
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 12-07-2007, 10:03
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
1714 used the Keyang window motor through a bane bots 56mm 12:1 transmission (the one meant for the cim). The motor worked great, but the transmission gave us problems all season.
For the second joint on our arm, we used a Nippon Denso window motor. We mounter the motor on the opposite side of the arm as the gripper to be used as counterweight. We ran a chain down the arm and used a 4:1 ratio. This section of the arm worked great all season.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 12-07-2007, 10:43
evanisthat!'s Avatar
evanisthat! evanisthat! is offline
Captin' Kassof
AKA: Evan Kassof
FRC #1902 (Exploding Bacon)
evanisthat! is just really niceevanisthat! is just really niceevanisthat! is just really niceevanisthat! is just really nice
Send a message via AIM to evanisthat!
108 used a globe motor on a 1.75:1 rack and pinion assembly to control the telescoping part of the arm and the other globe motor on a 30:1 worm gear reduction to rotate the arm. Although it was pretty slow, it was controllable and reliable. In fact, the arm assembly never failed through 3 competitions, it just never worked great to begin with . Hope this helps.
-Evan
108!!!
2007 Las Vegas Xerox Creativity Award winners!
2007 Las Vegas Quarter Finalists, only alliance to challenge the champs!
2007 UCF Finalists... thanks to 1902, 179, and 386 for the crazy jump in!
2005 UCF regional quarter finalist...
2005 Midwest regional quarter finalist...
2005 UCF Website Winner
2005 Midwest "Delphi Driving Tomorrow's Technology" Award.
2005 Championship Curie Division Champions. (thanks to team 175 and team 33).
Unread 12-07-2007, 11:33
Aren_Hill's Avatar
Build Nifty Things
Which arm? our first telescoping 1 used a fischer price through 64:1 42mm banebots. the second 1 used a globe motor with 2 sprockets and the rebuild of the second one now uses the fischer price through a lead screw it works amazingly well
A guy who likes robots.
Unread 12-07-2007, 11:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
1726 used the small Banebots motor and a 125:1 Banebots gearbox. this drives an 8:1 chain reduction, and the arm is mostly supported by a gas spring. it worked all season, and is still working (they're playing with autonomous programming now).
AJ R--I'm not at all surprised that you're having trouble with the 56mm Banebots transmission...think about what you are doing to it, you are driving it with a gear reduction motor that can put out way more torque than the transmission is designed to handle.
Unread 12-07-2007, 11:42
Tim Baird's Avatar
Tim Baird Tim Baird is offline
Design Ninja
FRC #0126 (Gael Force)
Tim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond repute
Send a message via AIM to Tim Baird
Gael Force used two FP motors this year, one for the lift and one for the extension. Both powered a ball-screw through repackaged FP trannies. The extension simply slide back and forth on bearings while the lift worked through a sliding four bar linkage.
Tim Baird
FRC Alum and FRC/FLL Volunteer
Project Engineer @ Nypro
History:
Gael Force 126: 1999-2000
WPI 190: 2001-2004
Gael Force 126: 2005-2010
Event Volunteer Only: 2011-Present
Unread 12-07-2007, 11:44
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
364 used the small banebots gearbox with the default motor (mabuchi?), and we used a globe motor for our extension.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 12-07-2007, 12:31
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
we used an AM Planetary Cim gearbox at 181:1. The arm can lift the whole robot.
Unread 12-07-2007, 14:23
Billfred's Avatar
Billfred Billfred is offline
Our first stage was a CIM and a 12:1 BaneBots gearbox, reduced another 1:3 (as I recall) through chain to the actual arm. The second stage alternated between a Denso and Keyang motor, although we never quite nailed that.
Unread 12-07-2007, 14:37
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
We used two Fisher price motors to move our two jointed arm, and then used a globe motor to rotate it and a window motor to open and close the claw. The problem with using a globe motor for the rotation was that it had no backdriving on it so we eventually broke the gear that was on the arm and had to lock the arm rotation half way through Curie.
I am always doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
--My Life in FIRST--
2009 Detroit Xerox Creativity Award
2009 Detroit District Finalists - Thanks to 1856 and 2620
2009 Kettering District Quarter-Finalists - Thanks to 1504 and 1025.
2008 Kettering Kickoff Champions - Thanks to 67, 1075 & 2619
2008 MARC Finalists - thanks 67 & 226
2008 Great Lakes Finalists - thanks 66 & 217
2008 Western Michigan Semi-Finalists - thanks 2337 and 1504
2008 GLR Judges Award Winner
2007 Curie Division Champions - thanks 330 and 1270
2007 ARC Champions (13 and 0, plus scoring a double-keeper!) - thanks 1625 and 313
2007 MARC Champions - thanks 1732 and 1023
2007 Xerox Creativity Award - Western Michign
2006 I.R.I. Champions - thanks 71 and 1625
Unread 12-07-2007, 15:42
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
One FP Motor (without original FP transmission) on a 64:1 BB transmission driving a 40:1 worm gear assembly for both the base and the arm.
BB RS540 motor in the 64:1 BB transmission that came with the kit for the wrist.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 12-07-2007, 16:02
AKA: Malhon Godwin
The Fischer price had more than enough power to move the arm. At our test days, I accidently snagged the corner of a tote full of tools and wire with our tube funnels on the arm, and when i tried to free it up, it flipped the tote over like it wasn't there. After competition, I was dinking around with the robot, and the arm was strong enough to lift the front of our robot off of the ground without a problem. For our wrist, we used the globe motors on a PID loop with a slight reduction.
Midwest Regional-
Unread 12-07-2007, 16:15
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
1885 Used a window motor connected to parachute chord with no xmission/reduction in the pulleys to power a simple elevator. We then used the Globe motor for the "shoulder" joint and the 2 tiny motors (the ones that smoke if they're run for more than 20 seconds at at time) for the claw movement.
GitHub
Unread 12-07-2007, 16:23
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
S.P.A.M had a 2 link arm with a grabber, this year. We used an F.P. for each link and an N.D. window motor for the grabber. We burned up a grabber motor or two during build and competition season.
Eric
Don't PANIC!
S. P. A. M.
What IDE DID you use? EHaskins Programming 15 22-02-2007 12:58
What programming environment did you use? StevenB Programming 10 18-03-2006 09:32
Drivetrain, what did you use? maclaren Technical Discussion 42 15-02-2004 21:09
What modeling program did you use? archiver 2000 5 23-06-2002 23:24
