#16
Re: pic: Planitary Transmission
Out of curiosity, where are you getting the combined spur/ring gear?
#17
I have taken a CIM apart on many occasions in the past to do many things to them (turning the shaft down to mate a pinion gear during the off season) and while the turning the shaft down destroyed the motor getting the bolts back in was extremely easy. It also happens that on our robot this year we had a big CIM that could only be taken out by taking the motor apart (it wasn't a bad design, it was my incompitent machining) and that big CIM still works like a dream. Quote:
On a similar note if anybody knows where to get a 20DP, 40 tooth ring gear that would help imensly cause mcmaster doesn't seem to have ring gears and stock drive products doesn't have 20DP gears. Thanks |
#18
Boston Gear doesn't have them. I am not to sure were else to have you check.
#19
Planetary Transmission
Alex,
Here are some words of wisdom from someone who has lived through the variable planetary gear train design and implementation cycle. 1. You do not get ANY added output torque from the ring gear motor ... zero, nada, nothing. The ring gear has to react against the input torque of the sun gear and adds nothing to the output torque. 2. The ring gear motor only changes the speed ratio. Designing it to not need motor torque at 0 RPM is a good idea, but the Denso motor worm gear may not be able to handle the load. 3. When sizing the gears, make sure when the ring gear is spinning in the opposite direction of the sun gear that the robot still moves forward. If you do not do this then any amount of force can stop you. However, you can pretty much stop any amount of force pushing you. 4. When designing your gear ratio's, there are three basic areas that the CCT gives you: Ring gear in reverse, ring gear at 0, and ring gear forward. Design your normal operating conditions at ring gear at 0 speed. 5. Read the paper that I attached here: http://www.chiefdelphi.com/media/papers/1361 -Paul |
#20
Re: Planetary Transmission
Either way, the motor sets do not both add to the output torque. The sun motor chain reacts against the ring gear motor chain, or visa versa.
#22
And if you are looking for a source of gears, check out what SDP-SI has to offer. |
| pic: 379's transmission | Robo_Cat_379 | Extra Discussion | 10 | 05-03-2007 08:48 |
| pic: 2 Speed Transmission | AustinSchuh | Extra Discussion | 20 | 30-12-2006 16:39 |
| pic: 2 speed transmission 1 | psyco_klown | Extra Discussion | 3 | 05-09-2006 19:03 |
| pic: 2 speed transmission 2 | psyco_klown | Extra Discussion | 0 | 22-05-2006 13:35 |
| pic: lego Planitary... Kinda | CD47-Bot | Extra Discussion | 5 | 14-07-2003 23:55 |
