Go to Post Just because something has never been done, doesn't mean it's impossible. See: everything ever. - Taylor [more]
Unread 16-07-2007, 16:40
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: Planitary Transmission
Out of curiosity, where are you getting the combined spur/ring gear?
--Madison--
...down at the Ozdust!
Unread 16-07-2007, 17:34
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Originally Posted by Jeff Waegelin View Post
I would be cautious about using the long screws in the CIM motors to mount a back plate. Once you take them out, it can be exceedingly hard to get the screws back in, due to all the magnets inside the motor. I've trashed a CIM before doing that, and I know a few other people have done similarly.
First off I haven't even said that this was the intended method of ataching the back plate but it is one that I have been thinking. I would be more cautious of doing this more because I might have a hard time finding just the right bolt.
I have taken a CIM apart on many occasions in the past to do many things to them (turning the shaft down to mate a pinion gear during the off season) and while the turning the shaft down destroyed the motor getting the bolts back in was extremely easy. It also happens that on our robot this year we had a big CIM that could only be taken out by taking the motor apart (it wasn't a bad design, it was my incompitent machining) and that big CIM still works like a dream.
I'm not. I would get a normal gear and a ring gear. I would bore out the normal gear so the ring fits inside and drill holes for pins to transfer the torque. The pieces that hold the ring/spur gear are also pins that could transfer the torque. I would have to try this before actually using it during the season cause it seems a little fishy in terms of actually working.
On a similar note if anybody knows where to get a 20DP, 40 tooth ring gear that would help imensly cause mcmaster doesn't seem to have ring gears and stock drive products doesn't have 20DP gears.
Thanks
Unread 16-07-2007, 17:43
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Boston Gear doesn't have them. I am not to sure were else to have you check.
Unread 16-07-2007, 21:23
President, VEX Robotics, Inc.
Planetary Transmission
Alex,
Here are some words of wisdom from someone who has lived through the variable planetary gear train design and implementation cycle.
1. You do not get ANY added output torque from the ring gear motor ... zero, nada, nothing. The ring gear has to react against the input torque of the sun gear and adds nothing to the output torque.
2. The ring gear motor only changes the speed ratio. Designing it to not need motor torque at 0 RPM is a good idea, but the Denso motor worm gear may not be able to handle the load.
3. When sizing the gears, make sure when the ring gear is spinning in the opposite direction of the sun gear that the robot still moves forward. If you do not do this then any amount of force can stop you. However, you can pretty much stop any amount of force pushing you.
4. When designing your gear ratio's, there are three basic areas that the CCT gives you: Ring gear in reverse, ring gear at 0, and ring gear forward. Design your normal operating conditions at ring gear at 0 speed.
5. Read the paper that I attached here: http://www.chiefdelphi.com/media/papers/1361
-Paul
Unread 16-07-2007, 23:13
Re: Planetary Transmission
It looks like Alex has designed his system "inside out" from the way you expect. If I'm reading the drawing correctly, the dual CIMs drive the ring gear, and the "variable" part is due to rotating the sun gear.
Unread 17-07-2007, 08:50
Either way, the motor sets do not both add to the output torque. The sun motor chain reacts against the ring gear motor chain, or visa versa.
Unread 22-07-2007, 06:14
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Please correct me if I am wrong, but I do not believe this design will work because of the fact that the window motor does not actually spin the central shaft, but rather the worm gear spins centered around the stationary shaft. However, adding a much larger adapter for the spline on the motor will separate the motors, changing the distances between the gears.
And if you are looking for a source of gears, check out what SDP-SI has to offer.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
pic: 379's transmission Robo_Cat_379 Extra Discussion 10 05-03-2007 08:48
pic: 2 Speed Transmission AustinSchuh Extra Discussion 20 30-12-2006 16:39
pic: 2 speed transmission 1 psyco_klown Extra Discussion 3 05-09-2006 19:03
pic: 2 speed transmission 2 psyco_klown Extra Discussion 0 22-05-2006 13:35
pic: lego Planitary... Kinda CD47-Bot Extra Discussion 5 14-07-2003 23:55
