Go to Post Some clever fellow a few years back made a little scooter based on this principal and made so much on the idea he can afford the finest denim in the land. - phrontist [more]
  #31   Spotlight this post!
Unread 15-07-2007, 18:48
ducttapedude ducttapedude is offline
AKA: Peter
FRC #0233 (The Pink Team)
ducttapedude has a spectacular aura aboutducttapedude has a spectacular aura aboutducttapedude has a spectacular aura about
Send a message via AIM to ducttapedude
Re: what motor did you use(arm)
Team 233 used one large CIM through a custum gear box to rotate our arm, and another large CIM through a custum gear box to extend the arm
Think Poof
  #32   Spotlight this post!
Unread 15-07-2007, 23:51
pythagoras's Avatar
pythagoras pythagoras is offline
AKA: Nicholas Wheaton
FRC #0067 (Heroes Of Tomorrow(H.O.T.))
pythagoras is a jewel in the roughpythagoras is a jewel in the roughpythagoras is a jewel in the roughpythagoras is a jewel in the rough
We used a CIM motor to drive te arm with the help of a andy-mark planetary gear system. we also used two globe motors on our end effector. We had to save our fisher-price motors for our lift.
  #33   Spotlight this post!
Unread 17-07-2007, 03:08
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Originally Posted by ChrisH View Post
Power = force x distance / time
As an example let's run the numbers:
We want to move a 0.5N object approximately 3 meters in 4 seconds. That will take 0.375 watts.
If we assume a 2m arm, we only actually need 0.5N *2m = 1Nm.
I puposely left out the power required to move the arm itself as that can be adjusted by using counter balances or springs.
So it really does not matter too much which motor you use as long as you use it correctly and keep all hardware within its operating limits.
Excellent points, Chris. I'm a physics teacher, so I get all geeked up when this stuff comes up. I see a mistake some teams make is under-estimating the amount of torque required to move not the game piece, but their robot's ARM! True any motor could be used to pick up the 1 lb tube, but what about that 1x1 box tubing and the grabber assembly at the end? 16 W Mabuchi motor?? Well, if the arm weighs a modest 10 lbs with its CM located 2 ft from the pivot = 20 ft-lbs (27 N-m)... That means that mabuchi would need to be geared down at least 1800:1 and moving 0.033 rps or 12 degrees/sec. Yikes or better yet, Yawn!!
I know Chris was simply making a point to look at the physics, specifically mechanical advantage of gearboxes. Hmmm... maybe we could re-write the Archimedes quote ... "if I had a big enough gearbox for my 16 W mabuchi, I could move the world". Another hmmm.. makes me think of an off-season project!!!
  #34   Spotlight this post!
Unread 17-07-2007, 10:45
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Then again you could also consider the arms moment of inertia because many of these arms have a large weight at the end of a long stick. So even if the motor can move the arm fast, it might take too long to get up the speed.
We didn't use an arm this year but we used one in 2005 and each joint was powered by a fischer price. I forget the reduction on the lower arm but the upper arm somehow got to 1157:1. Not by design, but hay it was a highly entertaining fluke.
Alex
  #35   Spotlight this post!
Unread 22-07-2007, 06:05
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Quixilver used the window motor for the shoulder joint and a globe motor on the elbow joint.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
  #36   Spotlight this post!
Unread 22-07-2007, 10:17
cgredalertcc cgredalertcc is offline
AKA: Charlie Baxter
FRC #1747 (Harrison Boiler Robotics)
cgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to all
Send a message via AIM to cgredalertcc
1741 used five motors on the arm assembly of our first robot. One keyang to move a shuttle up and down. Two fischer prices and one that ended up having to be changed multiple times (started as a keyang, then went to a globe on a custom worm drive gear box, and finally the banebots planetary on that same gear box). Finally we used one globe to adjust the pitch of our gripper via a screw drive. This system was extremely complicated and we chose to build an entire new robot for IRI. This new one used two banebots planetarys one on either end of a worm gear that moved the arm around a fixed gear on the shaft which was also fixed to our tower.
The moral of the story simple is almost always equal to better.
  #37   Spotlight this post!
Unread 22-07-2007, 17:23
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
1024 Used both large CIMs for the manipulator... worked out well, 0->12ft on the elevator in 0.9 seconds.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
  #38   Spotlight this post!
Unread 25-07-2007, 00:29
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
We used the large CIM motor with 3 to 1 belt drive to a 2 in pully to wench up 8020 slid on a slide. The claw we used was large enough to grab a tube from the outside. When the tube was in the claw it took no time for it to go to the top spur. We did not want to wait for it to crank up so we made sure it would get thier fast. For the claw we used pneumatics pulling steel cables to close the claw and springs to open. http://team1322.org/DESIGN1.jpg
  #39   Spotlight this post!
Unread 25-07-2007, 00:34
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
We used a CIM motor straight into an AM Gearbox which drove the arm.
I win! XD
  #40   Spotlight this post!
Unread 25-07-2007, 17:50
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
We raised and lowered our arm with the Keyang window motor. We attached the motor to the arm itself, so we could use it as a counterweight. Originally, we planned to use another window motor to telescope our arm, but we swapped that for pneumatics late in the build season.
What IDE DID you use? EHaskins Programming 15 22-02-2007 12:58
What programming environment did you use? StevenB Programming 10 18-03-2006 09:32
Drivetrain, what did you use? maclaren Technical Discussion 42 15-02-2004 21:09
What modeling program did you use? archiver 2000 5 23-06-2002 23:24
