Go to Post I don't thinks shorts should be allowed in the pits. Remember to insulate all of your wires! - Jalerre [more]
Unread 17-07-2007, 11:04
Chris2 Chris2 is offline
AKA: Christopher
FRC #0269 (CooneyTech Robotics)
Team Role: Webmaster
Chris2 has a spectacular aura aboutChris2 has a spectacular aura about
Download MPLab
Is this the place to go to download the latest version of MPLab so I can program the 2007 robot?
I know that the software will probably only work for 30 days without a license key.
CooneyTech Robotics Website
Unread 17-07-2007, 11:19
Re: Download MPLab
You need both MPLab and the C18 compiler. MPLab is free and that download you linked should work (you can also use later versions).
The C18 compiler is not free. You need to use version 2.4, which has come in the kit every year for the past few years. If your team has misplaced all your old CDs, you can purchase it from Innovation FIRST (for much cheaper then the full retail version). There is a student trial version of C18, but it is version 3, which will not work for the robot.
Unread 17-07-2007, 11:28
AKA: Christopher
Re: Download MPLab
Where do I get the later versions?
Unread 17-07-2007, 12:29
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Re: Download MPLab
I did a search on the microchip website for the c18 compiler. Once you find the page do download it, you need to set up a microchip account to show that you are a student. Then you can download the newer versions, but as Joe said, it will not work with the robot.
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 17-07-2007, 13:41
Re: Download MPLab
Later versions of C18 won't work. The latest version of MPLAB is here: http://www.microchip.com/stellent/id...&part=SW007002
Unread 18-07-2007, 01:37
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: Download MPLab
You can get a 60 day trial student version 2.40 of the c18 compiler, which will work to program the robot, here: https://jvex-robotics.dev.java.net/f...c18_240_se.zip
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 18-07-2007, 17:55
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Download MPLab
I you have EasyC you can use the copy of mcc18 that is at "C:\Program Files\Intelitek\easyC Pro\#Tools\mcc18".
Eric Haskins KC9JVH
Unread 01-08-2007, 06:58
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Re: Download MPLab
That's exactly what I did. It works great too. So you can just download a trial version of EasyC for FRC and install it, download and install MPLAB IDE, link your MPLAB project to the compiler in the EasyC directory, and you just got yourself a free programming environment
where can i download the mplab c18 compiler v2.40 amirjpl Programming 5 27-03-2007 20:37
I need help pls!!I want to download MPLAB 7.2 Krupalkavathia Programming 5 22-03-2007 02:41
controller download druman Control System 2 20-02-2006 13:17
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
Help me download mjt902 Programming 3 31-01-2003 15:37
