Go to Post The major items of FIRST are still what they always were.....understand the game, build a reliable quality machine to play it, train you drivers to use it to its full potential. If you do these things, you can win with or without any specific machine feature. - Jim Zondag [more]
Unread 17-07-2007, 14:18
Demothesis's Avatar
Demothesis Demothesis is offline
Team Leader/Programmer
FRC #2169 (KING TeC)
Demothesis is on a distinguished road
Question How do you wire the wheel encoders?
We got a packet called "Analog Devices Sensor envelope" and another called "Gear Tooth Sensor Envelope." Which is the wheel encoder, if any? How do you wire it? What do the "pins" mean/do?What will they output? Do you need to input anything? (they are actually just solder joints that we soldered leads onto.)
How do you get them to work?!
A full explanation would be very much appreciated, but even if you have just a little idea to get us started would help.
Thanks, Demothesis
Unread 17-07-2007, 14:56
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: How do you wire the wheel encoders?
The gear tooth sensors can be used as encoders if you put them near a gear or sprocket in your drivetrain. This document will tell you how to wire them up, and also will point you to other documents with application notes:
http://www.ifirobotics.com/docs/2006...h-sensor-b.pdf
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 17-07-2007, 16:59
Demothesis's Avatar
Smile Re: How do you wire the wheel encoders?
All right!
Thanks a lot. I'll post back if I have any problems, but that in combination with Kevin's FRC Code repository (if even necessary) seems to be sufficient.
Thanks again, Demothesis
how do you wire the team light coolguybigt Robot Showcase 2 21-02-2007 22:18
How do you mount the encoders to the Gear boxes? waialua359 Technical Discussion 5 01-02-2006 21:07
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
How do you wire a limit switch? JMH Electrical 1 16-02-2005 17:44
How do you wire ADXRS150EB gyro? MaxM Electrical 2 16-02-2004 13:43
