Go to Post Imagine your crate going over Niagara Falls => pack it accordingly (esp if you are attending the Toronto Regional :^) - KenWittlief [more]
Unread 17-07-2007, 13:33
AdamHeard's Avatar
Lead Mentor
pic: What are these parts?
Smaug's Avatar
Smaug Smaug is offline
FRC #0675 (Tech High Phantom Robotics)
Team Role: Electrical
Smaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the rough
Re: pic: What are these parts?
if it is for vex i would say it would be used gathering balls
If it isn't broken, Fix it till it is ~ Baker
Unread 17-07-2007, 13:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
towel rack from the Space Shuttle bathroom?
Unread 17-07-2007, 13:55
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
hmm, Judging by the fact that they are titanium and have serial numbers I want to sat they are medical parts. I have seen plates and screws for fixing serious bone fractures and breaks. They have all had serial numbers on them.
So my guess is that they are meant for medical use.
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 17-07-2007, 14:04
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
With ya on that one, If you look on the ends of the curved piece, they are notched, meaning they're adjustable, and they look like they slide into the little mounting brackets. Definately something medical, but can't tell you what.
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 17-07-2007, 14:37
CraigHickman
Posts: n/a
I'm not convinced of the medical part. Titanium 6Al4V is normally used in Aircraft due to its excellent heat properties... So I'm guessing it's something from some sort of aircraft...
The part that really confuses me is that Titanium 6Al4V is usually used inside the turbines and jet engines, because of its heat resistance.
So I have no clue, only more pieces to the puzzle.
Unread 17-07-2007, 14:48
AdamHeard's Avatar
Lead Mentor
You got it... these just got back from spending 2 1/2 years in my chest from a kickboxing injury.
EDIT: I like the towel rack guess.... I've been working in aerospace a while and it would fit right in to make something so trivial entirely more expensive and stronger than it would ever realisticaly need to be.
Unread 17-07-2007, 14:57
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Break your sternum?
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 17-07-2007, 15:26
AdamHeard's Avatar
Lead Mentor
No, I tore the cartilage near the sternum pretty bad.
There is a condition known as "pectus excavatum" which is that "hole" in the chest you see on some people, I apparently had a very, very slight case in which you cuoldn't even tell really. When I get kneed perfectly lined up there, it pushed in rather far and became a rather severe case... It was even cutting off one of my bronchial tubes almost completely (It also was pushing on my heart and supposedly raising my blood pressure). the bar had to be put in to flatten it out while it regrew (which apparently takes a long, long time...).
Unread 17-07-2007, 16:02
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
Kinda gross, and yet totally amazing at the same time!
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 17-07-2007, 16:04
CraigHickman
Posts: n/a
Wow. I've done martial arts my whole life, and I've never seen that kind of injury... However, I have seen ribs shattered... is that similar?
Glad that things out, cuz that means you're better.
Unread 17-07-2007, 16:09
Go VOLS!!
AKA: Budda648
no team (QC Elite)
The injury wasn't completely from martial arts. It was a defect that went unnoticed(?) and was aggravated by the kick. So, take for example, had he falled on a soccer ball on his chest, it may have happened anyways. Just unfortunate... but it's good that he is better.
Do The Tyler!
Unread 17-07-2007, 16:28
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
looks like you broke an ice bucket to get the handle and a small jewelery chest for the hinges
Championship - Delphi "Driving Tomorrows Technology"
Unread 17-07-2007, 16:47
run the trap!!!
Team Role: Human Player
If I were you I'd use it on next year's robot.
It would make a great conversation piece with the judges
Judge - "So where did your team get the titanium?"
You - "Oh... I had it surgically removed from my chest..."
-Philip J. Fry
Unread 17-07-2007, 18:22
GaryVoshol's Avatar
Cogito ergo arbitro
The cost accounting might be prohibitive ... especially if you have to account for the "installation charge".
(since 2004)
pic: 968 - These parts are nice and simple! Travis Covington Extra Discussion 1 31-01-2007 13:53
pic: These elevators are fast! artdutra04 Extra Discussion 7 08-01-2007 11:09
Are these wheels available, anf if not are they ever gonna be? Elgin Clock FIRST Tech Challenge 3 12-11-2005 22:27
pic: FIRST veterans knowledge needed. What kind of motors are these? CD47-Bot Extra Discussion 12 24-07-2004 13:25
Are these mat'ls legal? archiver 2000 1 24-06-2002 00:15
