Cmucam2+ Problems
Hi,
I purchased the CMUcam2+ in order to have the camera integrated in to a robot. When I power the camera using a 8.5 DC adapter, 350mA, the Power LED turns green and the SX52 processor on the camera's PCB gets so hot that you can't touch it(about 50 + degrees C)! My question is; is this normal?( I am assuming not) How can I fix this? I tried a 6 V power supply made of 1.5 V alcaline batteries and the SX52 still heats up! 1.I tied to set up communication with a PC by building a RS232 Level Converter with no luck. 2. Tilt/PAn auto mode does not work as outlined in the CMUcam2 manual. 3. None of the status LED's light up |
| CMUcam2 LabVIEW GUI problems | StevenB | Programming | 1 | 21-01-2006 03:08 |
| Labview problems and code problems | ajsetter | Programming | 25 | 18-01-2006 17:07 |
| Problems tracking with CMUCam2 in LabVIEW | PhilBot | LabView and Data Acquisition | 5 | 17-01-2006 20:42 |
| CMUCAM2 Recognition Problems | muy dificil | Programming | 0 | 04-11-2005 11:32 |
| CMUCam2 Vision Sensor Testing/Problems | cbolin | Programming | 18 | 02-02-2005 18:03 |
