Go to Post H.A.T.E.R.S. = Having Anger Towards Everyone Reaching Success - pandamonium [more]
Unread 26-07-2007, 21:00
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
pic: Custom Machined Aluminum #25 Sprocket
Unread 26-07-2007, 21:01
AdamHeard's Avatar
Lead Mentor
Re: pic: Custom Machined Aluminum #25 Sprocket
Looks nice... These were in the drive I assume.
How long did it take to machine? How many set ups? (I'm assuming one on a CNC mill and one on a waterjet/lathe)
do you know if the amount of weight saved (how much did it save?) was worth the extra time?
Unread 26-07-2007, 21:09
Holtzman's Avatar
Sometimes...
AKA: Tyler Holtzman
Machining time was a little over an hour. 1 setup on the mill. Holes were tapped by hand afterwards. Slight tooth chamfer was done on the lathe afterwards.
Was it worth the time? Probably not, but they do look nice.
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 26-07-2007, 21:16
AdamHeard's Avatar
Lead Mentor
Did you cut the teeth on the mill as well?
If so, what diamater cutter was used?
Unread 26-07-2007, 21:26
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Are those radiused areas in the center contoured?
Or do they just happen to be the same radius as a ball endmill you ran through there?
Those are some sick sprockets.
2001-2004: Team 100
2006-Present: Team 254
Unread 26-07-2007, 22:04
CraigHickman
Posts: n/a
Woah. I don't think I've seen a sprocket that sexy since one of 233's huge pink ones.... This one is just elegant though! It makes me wish more and more that my team had a CNC...
Nice job!
Unread 26-07-2007, 22:16
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
two words: SICK NASTY!
190 had AL drive sprockets (31 teeth, I don't know why they HAD to be 31 teeth), but they were no where near as sexy as that beast...nicely done
Unread 26-07-2007, 23:02
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Pretty snazzy!
Form does indeed follow functionality.
Unread 26-07-2007, 23:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What feedrate did you cut it at? That's a lot of material to remove just to avoid using spacers. But it does look quite nice.
Unread 27-07-2007, 00:31
Jonathan Norris Jonathan Norris is online now
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
TyTown those sprockets are absolutely ridiculous, I want one
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 27-07-2007, 08:55
alex1699's Avatar
alex1699 alex1699 is offline
ummmm thats meee......
FRC #1699 (robocats)
alex1699 has a spectacular aura aboutalex1699 has a spectacular aura aboutalex1699 has a spectacular aura about
Send a message via AIM to alex1699
as Borat would say "Very Nice"
Curie..
Unread 27-07-2007, 12:22
Billfred's Avatar
Billfred Billfred is offline
Wow.
Unread 27-07-2007, 13:30
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
It wouldn't take much to cover the teeth and powder coat it for an genuine look either. Very nicely conceived, though I'm curious as to what a F.E. Analysis on it looks like. It looks at first glance as though the dips on the inner ring between the sets of holes would be the weakest points.
GitHub
Unread 27-07-2007, 13:36
AdamHeard's Avatar
Lead Mentor
Probably true, but it looks to be atleast as thick as the standard sprocket thickness there. So, it is no weaker than a normal sprocket most likely.
(this is just an assumption... If I had the model, I'd run FEA on it to verify)
Unread 27-07-2007, 13:47
REVving up for a new season
FRC #2848 (All-sparks)
I don't think the thickness is under question it is the webbing on the profile.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
pic: MVRT1115 small machined parts Ashwin Extra Discussion 5 23-02-2007 13:22
pic: 254/968 Machined Parts Cory Robot Showcase 11 12-02-2007 07:42
pic: Team 1538's Machined Parts (C) Jon Jack Extra Discussion 19 23-01-2007 02:06
pic: 1538's Machined Parts (B) Jon Jack Extra Discussion 2 21-01-2007 20:31
#25 Aluminum Sprocket Source Don Wright Kit & Additional Hardware 1 26-01-2005 13:41
