Go to Post I think CD is worth about 3 billion in Google stock. Talk about one hell of a fundraiser! - Joe Matt [more]
Unread 28-07-2007, 12:58
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
pneumatic potato gun i made
hey guys. ive been working on a pneumatic potato gun all summer and i tested it for the first time today and it didnt work
i was hoping you could give me some tips on how to make it better.
well i used the kind of minimatic cylinders that were in the kit this year.
i pumped up one of them to 90 psi and attached it through a valve to the end of a 2 foot long peice of 2" diameter PVC pipe. i cut a potato to a bit smaller than the diameter and put it in the pipe. but when i release the valve i hear air coming out but the potato just sits there.
im not sure what i can do besides get more air tanks and put them on a manifold. i am going to try to get a part so i can put a second tank on there.
but does anyone have any tips on how to make it work better?
thanks, vivek
Unread 28-07-2007, 14:04
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
Re: pneumatic potato gun i made
I built an air powered potato gun last fall.
From experience, I've found the best way to fit a potato to the barrel.
  • Cut a potato in half down the center, into two bullet shaped halfs.
  • Place one half, cut side down, on the ground and force the PVC pipe over the half to cut the potato to the perfect fit to your barrel.
  • If you need to, take a stick and push out the shaped half, and reinsert it into the barrel so that the slightly rounded end is pointing at what you want to shoot at. (This makes for a more stable shot)
Try this, if this doesn't work, some pictures of your rig would be helpful for more advice.
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 28-07-2007, 14:25
vivek16's Avatar
AKA: vivek
thanks, ill try that and get back to you with some pictures.
-vivek
Unread 28-07-2007, 21:01
DonRotolo's Avatar
Back to humble
FRC #0832
Exactly: A tight seal is a requirement.
Also, how much air are you pushing? It needs to be about 4 times the volume (at least) of the PVC tube.
Lastly, with 90 PSI, consider that the shock loads may cause the pipe to shatter. Two ways to make it safe, first encase the bottom 2/3 of the pipe in a larger pipe (no matter the size as long as it fits over the inner pipe), so the larger pipe will catch any shrapnel, OR second wrap pliable tape (like electrical, duct, or fiberglass packing tape) in a 1/4" to 3/8" layer around the lower 1/2 of the pipe, that'll slow down the shrapnel to nonlethal speeds.
Unread 29-07-2007, 10:11
vivek16's Avatar
AKA: vivek
1) i am not using pvc to hold the pressurized air, i am using the type of air tanks that we got in the kit this year.
and i think that i might perhaps cut the "barrel" part of the gun down because one tank full of air causes the potato to go 2/3rds of the way through the barrel so i think i will add the second tank and maybe it will work then.
also, the tip on how to make an air tight seal really helped, thanks.
-vivek
Unread 29-07-2007, 10:28
vivek16's Avatar
AKA: vivek
well the volume of the barrel is about 80 in" squared. and there is definetely no chance of exploding pvc. no pvc is ever pressurized in my setup.
here is a sketch.
sorry about the size but there are 2 metal tanks that go through a valve and then to the barrel.
single tank with pressure gauge
the whole setup as it it now but that lone peice of pvc near the bottom is the tank inside its pvc casing through the valve to the barrel.
the inside of the barrel and the bulkhead where the air comes out of (yes the barrel screws off makes it so much easier to carry around and put in more potato pellets)
-vivek
Unread 29-07-2007, 10:53
DonRotolo's Avatar
Back to humble
FRC #0832
OK, so you're using a piston to push air from the big PVC pipe into the smaller PVC pipe. I agree there is little safety to be concerned about with this scheme, but think about what is pushing the potato.
One clippard tank isn't enough, you don't have enough volume to move the piston fast enough. Try using as many as you can get, but plumbed in parallel, not in series, such that the greatest volume of air can move. Here pressure is secondary to volume.
If this isn't clear, I can explain further.
Don
Unread 29-07-2007, 11:12
vivek16's Avatar
AKA: vivek
Don
no, i am NOT using a piston. i hooked up the tank to a valve which sends all the air to the barrel through a push in connector.
ok, i will try to get some more parts to get the second tank to be in parallel with the first one. i think i know how i can do this.
Unread 29-07-2007, 16:19
DonRotolo's Avatar
Back to humble
FRC #0832
OK. Part of the problem is I can't see the sketch too well.
The air that enters the barrel is pressurized. That is the pressure I was writing about with safety and shock loads. As you continue, please consider what I wrote. PVC pipe might be rated for 150 PSI, but that's not a shock load - it might only withstand 1/2 that.....
To launch a projectile, you need to get a lot of pressurized air behind it. If the barrel is 80 cubic inches, and you have 8 cubic inches of air (about what a clippard tank holds) at 90 PSI, releasing it into the barrel changes the pressure to 9 PSI. Do you see how that works? (The calculations are actually more complex, really resulting in less PSI, but the principle is the same).
Now, if you release 80 cubic inches of 90 PSI air into the barrel, you end up with a total of 160 cubic inches of 45 PSI air. Start with 800 cubic inches of 90 PSI air and you get 880 cubic inches of about 80 PSI air... See the way this is going?
OK, now the other half of this is getting the air into the barrrel quickly. If you use a 1/8" pipe to move the air into the barrel, it'll take 3 or 4 seconds to let the air in, and that's much too slow. Use 3/4" copper plumbing pipe, and the difference is dramatic.
OK, that's enough for you to go on, let us know how far your half of a potato goes...
Don
Unread 29-07-2007, 19:19
vivek16's Avatar
AKA: vivek
the pvc i have is rated for 280 psi so i think ill be fine there. im using 1/4" tubing. i think ill cut the barrel down to 2/3rd size
-vivek
Unread 29-07-2007, 20:29
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
PVC isn't rated for air though. Due to it's properties it can shatter into sharpnel and the reason OSHA won't allow it for air lines in shops. If the potato gets stuck or something else happens the pipe can explode like a hand grenade. Just something we're trying to make you aware of.
1/4" ID tubing will really restrict the volume, and more volume is what Don was hinting at for you. If you don't have anything bigger than 1/4" (I imagine you are using the same SMC polyurethane tubing we got in the KOP) and you don't want to buy anything bigger then try adding several feeds of the 1/4" tubing to your gun. This will help the tanks discharge faster which equals greater volume.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 30-07-2007, 00:01
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
After I was bored at a summer robotics meeting last year, I tried to make a pneumatic cannon out of only KoP items from this and past years. Even with 3/8" tubing, the volume of air rushing through the hose was barely enough to launch the plastic lid from a spray paint can about 20 feet. You need at least 3/4" ID pipe/tubing to make it work well.
Art Dutra IV
世上无难事,只怕有心人.
Unread 30-07-2007, 13:41
vivek16's Avatar
AKA: vivek
well i am a little short on funds right now so i am waiting for our representative person from our sponsors where we have our workshop to reply if i can buy some parts from him. i think he is on vacation right now.
-vivek
Unread 30-07-2007, 23:55
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
ther'es your problem
more power Grunt! Grunt! Grunt!
you need lots of air quick. a valve that opens to high flow real fast and larger tubing. big hose= high flow. 90psi is nothing for a hand held gun i typically use co2 at about 850Psi. even with compressed air i go up around 250psi.
Unread 07-08-2007, 10:28
vivek16's Avatar
AKA: vivek
well i made them into a paralell connection but the brass fittings in between them are rather small so when the air comes out it sort of flows slowly. I thing that i might try to launch a potato but i was too tired yesterday.
-vivek
potato cannon northendchopper Chit-Chat 14 16-12-2009 12:19
Potato guns Adama Chit-Chat 24 22-08-2006 13:16
Air gun length Max Brin Technical Discussion 9 16-01-2006 15:45
Couch Potato Anyone? TravisCarpenter Chit-Chat 6 05-09-2002 16:48
heat gun Lake Orion OCCRA 2 21-10-2001 23:34
