Go to Post If there was no internet then somebody in FIRST would probably invent it. - Koko Ed [more]
Unread 27-07-2007, 16:58
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Nut for Bimba Piston
I have run into a simple issue. I just received our AndyMark 2 Gen 2 pneumatic shifters and started working on it when I realized that I do not have the nut that holds the piston onto gearbox. According to the PDF on AndyMark's site it should come with the piston (3/4" bore, 1" stroke pneumatic cylinder. Bimba part #: M-041-DP) but it did not. Not a big deal except for the fact that I cant find a nut to go on it at all. Does anyone know what size it is? Thanks.
Chris
Unread 27-07-2007, 18:02
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Re: Nut for Bimba Piston
We had the same problem that you did. We got the same size cylinder but couldn't find the nut to go with it. It was a while ago but I think I remeber it being a 5/8-16. I'm pretty sure of the size and less on the thred pitch.
Hope this helps
Unread 27-07-2007, 18:30
Team 2021 Captain
AKA: Chris Davidson
I should have said that I was pretty sure that it was 5/8in but I didnt know that the thread was. All I saw at Lowes did not work. I think it was 5/8-11. Ill have to go back. Can anyone confirm exactly what I need? Thanks.
Unread 27-07-2007, 18:37
Alan Ing Alan Ing is offline
None #0368 (Kika Mana)
Alan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond repute
Smile Re: Nut for Bimba Piston
Pretty close guys, but a 3/4" bore bimba cylinder takes a 5/8" - 18 Threaded nut.
This is straight from the pneumatics manual. We have had to buy a bunch on our own in the past.
Unread 27-07-2007, 18:52
Team 2021 Captain
AKA: Chris Davidson
Duh, I cant believe I didnt check the manual. Thanks!
Unread 29-07-2007, 20:34
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
If you can't find it at Home Depot/Lowes then try a local hardware store, autoparts store or you can order them from MSC or McMaster-Carr, although there may be a minimun order for the last two.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 29-07-2007, 21:30
Team 2021 Captain
AKA: Chris Davidson
I couldn't find it at Lowes or Home Depot so yesterday I placed a McMaster-Carr order with some other stuff that I needed to order.
Suction Cup Nut IfIwasarichman Technical Discussion 5 31-01-2007 08:21
.... You might be a FIRST nut Horman Havoc Chit-Chat 16 11-01-2007 22:39
A cheap resource for parts, (terminals, wire, & Bimba pistons $40.00) RudimentaryPeni General Forum 1 04-01-2007 14:23
2 Hours Sleep and I cannot bear to see another nut or bolt.. archiver 2001 2 24-06-2002 00:54
Lead Screw Nut archiver 2000 1 23-06-2002 22:49
