Go to Post And let's face it their junk is our robot! - jrgrim12 [more]
Unread 31-07-2007, 02:00
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
O/I POWER?
Hey I am trying to run power to the O/I through the competition port to give power to the O/I. Does any body know what pins are used for power input to the O/I. I have sen team 537 provide power from there setup through competition so if anyone from 537 or and other team knows how this would be much appreciated information.
Unread 31-07-2007, 02:10
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: O/I POWER?
You could just ask me...
Here is a complete pinout of the competition port:
1 Positive Power In
2 Unknown
3 +5V to bypass P05 countdown and disable radio (put the controller into "tether mode")
4 Unknown
5 Autonomous Enable
6 Robot Disable
7 SCLK
8 Ground
9 N/C
10 Radio serial data in (from radio tower)
11 Radio serial data out (to radio tower)
12 Channel Access Enable
13 Competition Mode Enable
14 SDA
15 Valid RX
PLEASE NOTE: I CANNOT BE HELD LIABLE FOR USE OR MISUSE OF THE INFORMATION CONTAINED IN THIS POST!!!
If you fry your OI, you're on your own!
Hope this helps!
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 31-07-2007, 02:45
popo308's Avatar
AKA: Brent
Re: O/I POWER?
Thanks
Unread 31-07-2007, 03:31
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Re: O/I POWER?
Just out of curiosity, why are you trying to run power through the competition port rather than just using the AC adapter?
Something else that might be somewhat helpful. One day one of our drivers got sick of always having to get the OI close enough to an outlet to use the AC adapter and he made a battery pack for it. He just bought one of those AA battery holders from radio shack and connected whatever connector the OI uses (the same one as the AC adapter uses, don't know what it's called) to it. It only requires 5-7 AA batteries. (I'm not sure how many exactly, I haven't worked with it for a few months and I forgot what voltage the OI requires)
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 31-07-2007, 08:46
Re: O/I POWER?
One reason suggests itself to me immediately: you would need to make only a single connection to the competition port to get power, enable/disable, and autonomous control simultaneously. If you did it that way, you couldn't accidentally power up the robot without having a disable switch available.
Unread 31-07-2007, 10:16
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: O/I POWER?
Just a word of caution: powering the OI through the competition port will void the warranty. Pretty much all of the equipment that people have right now is probably out of warranty anyway, but it doesn't hurt to mention it in case someone decides to try this in January with their brand-new OI.
Check the schematic at: http://www.ifirobotics.com/docs/comp...guide-reva.pdf
Note the text in bold caps (emphasis mine):
CONNECTIONS TO ANY OTHER PINS CAN DAMAGE THE OI AND WILL VOID ANY WARRANTY
Unread 31-07-2007, 11:28
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: O/I POWER?
I have done this, but it is easier to just use a 9 volt battery. That way it is the right voltage without screwing around with 6 batteries.
Unread 31-07-2007, 11:55
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: O/I POWER?
On our 2006 OI, we had a spot to hook up a bunch of 9V batteries in parallel. Although we never used it, it would have been very helpful in many situations provided that we actually had 9V batteries.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 31-07-2007, 13:12
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Re: O/I POWER?
I made a small portable power supply for this years controller (2 9V batteries in parallel to power the OI) but the OI surges so much that all analog ports mess up. The robot will do very random things if you use the analog ports of the 15pin connectors. We used ours for many things such as our presets, extension and the hold button. The robot would go crazy with the presets, and the extension would work occasionally.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 31-07-2007, 13:40
Re: O/I POWER?
We played around with a portable power supply early this year. Having been part of the First Robotics Competition for so many years, we had a bunch of ancient 12-volt drill battery packs and chargers sitting in a forgotten corner of our shop. I found some that worked and made up a cable that plugged into the OI power input at one end and had connectors that attached to the battery at the other. The voltage was fine, and the operator could wander around the shop controlling our prototype Mecanum 'bot with nothing tying the OI to the wall.
The battery packs were not in the best shape, and only lasted for about 10-20 minutes before they would stop powering the OI reliably, but as a proof of concept it worked very well. I'm thinking we could build an operator console for robot demos that has a slot to plug in a drill battery, like the way the robots themselves were powered in the mid-'90s.
Unread 31-07-2007, 14:03
AdamHeard's Avatar
Lead Mentor
Re: O/I POWER?
This was perfected after two years and we love it.
Our OI box has a wiring harness that is always connected the the AC adapter port, this goes to a switch; battery power or AC power.
the battery power is supplied by a standard VEX or RC battery (we put a tamiya connector in to mate to the batteris without mods).
When it is in AC power mode, there is a charging circuit similar to what was reccomend to be used on the robot this year that charges that battery.
We also used the power from that battery to power our USB chiclet.
So far, we found this to be much more elegant and easier to use than normal batteries.
Unread 31-07-2007, 15:57
popo308's Avatar
AKA: Brent
Re: O/I POWER?
Well we are doing a mini robot competition on the off season untill Jan to get the new freshman involved with inventor and the metal shop. So we needed a 'Arena Controller' basically that would send the enable. disable, auto, and manual signals to all the O/I's. So we also needed someway to power all of this so thought why not go through the competition port since we already need to run a ton of cable for tha.
Unread 01-08-2007, 02:25
popo308's Avatar
AKA: Brent
Re: O/I POWER?
Hey, another question would a computer power supply be able to power and o/i with the 12v out with 4.2 volts? would it be able to power 6 o/i's?
Unread 02-08-2007, 17:18
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Re: O/I POWER?
All O/I's (and arena controllers) have a 9vdc Input Rating, Using a 12vdc Computer power supply would not by wise to power 1 O/I let alone 6 of them.
I suggest going here and making a cost effective portable battery pack, Simple to create and can be re-used over and over again espicially if the batteries used are rechargable and you design a charging circuit to go with it.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 02-08-2007, 23:32
AdamHeard's Avatar
Lead Mentor
Re: O/I POWER?
They want to build a field control system, so this isn't really a suitable option for them.
Why not just buy a 9V power supply that can source enough current for 6 OIs?
Automatic Power Swampcoder2 Control System 6 03-02-2005 17:08
ROBO-POWER 12th-martyr General Forum 2 07-04-2004 18:02
OI power rocko Electrical 3 06-02-2004 19:30
Solar Power? dddriveman Electrical 26 26-06-2003 18:44
No Power UCGL_Guy General Forum 8 05-02-2002 15:54
