Go to Post The function of that part is to keep one student occupied playing with it during the entire build season. It doesn't have to be the same student all the time, they can take turns. - MrForbes [more]
Unread 31-07-2007, 14:07
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: Interactive DashBoard
Originally Posted by eshteyn View Post
the program is absolutely fantastic, you did an amazing job
Thanks, did you have any problems with the instructions or getting it running?
EVERYONE:
I might not have made this clear because it got buried in the instructions, but you need to DISABLE ANY DIAL-UP/FAX modems on your computer(use the device manager). I don't know if this affects USB to Serial converters. For some reason it screws with the serial port and outputs garbage data.
PLEASE TURN OF YOUR MONITORS WHEN NOT IN USE!
Start using the power saving features! Don't worry your computer won't die.
Interactive Debugger/Monitor duane Programming 10 11-10-2006 23:26
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
FIRST Interactive Rural SupporT coreyk FIRST Interactive Rural SupporT 1 12-11-2003 10:31
Interactive Map - Out of Date Don Knight General Forum 0 19-09-2002 17:54
interactive strategy piconysm Rules/Strategy 5 11-01-2002 08:47
