Go to Post i build robots. i like robots. i live with robots. i love robots. i AM a robot. - tgoral2826 [more]
Unread 01-08-2007, 00:00
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Globe Help Please
I have been trying to dig up some information about the globe motors used in the KitOfParts and thanks to Karthik was able to get as far as the data sheet and the specs. BUT I am unable to find any retailer for is motor and so I was wondering if anybody knows any similar motors made by Globe with around the same size and shape and with more, less, or equal power. If you can help me I would greatly appreciate it.
The model number for the globe motor is - 409A587 and you can view the specs I have on it by clicking here.
Thank you for your help,
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 01-08-2007, 11:31
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: Globe Help Please
Years ago I contacted Globe about the motors. Apparently the motors donated to FIRST have a unique part number indicating they are "for educational purposes". They are probably re-numbered versions of another motor Globe produces, but I don't know which one. Good luck figuring it out.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 01-08-2007, 14:28
Pavan,
As so many manufacturers have done, Globe allows you to couple a specific motor and a specific gearbox. You just have to look at the specs and by them separate and then couple them together. Remember for our motor, Globe leaves the mounting flange off our part. We know that the gearbox is a 117:1 reduction, the motor is .98 oz/in of torque no load and the no load speed is 79.87 RPM calculated. Working backwards 117 x 79.87 is about 3950 RPM for the no load motor speed and stall current of 21 amps. You ought to be able to use that data to determine a motor and gear box.
Unread 03-08-2007, 19:49
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
In the 2007 Good Practices paper (http://www2.usfirst.org/2007comp/other/2007%20Guidelines_Tips_Good%20Practices_RevC.pdf), the Globe Motor is described as being used for "4WD/2WD transfer mtr." A little search on Wikipedia revealed that this motor would be found in the transfer case of an automobile to shift between 4 wheel drive and 2 wheel drive. And Globe Motors makes transfer case actuator motors, but does not let you use this in a product description search. However, this information might help you find some leads.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 10-10-2007, 15:14
sgebhart sgebhart is offline
sgebhart is an unknown quantity at this point
Pavan,
I came across your blog about Globe Motors part number 409A587.
A released drawing does not exist for this part number, so it was a special number created for a non-production opportunity.
The motor/gearbox that you are referring to, as defined in this part number, is actually part of an assembly that can be found on a large share of active four wheel drive transfer cases on four wheel drive vehicles around the world.
If you can explain in detail why you need such a motor to my satisfaction, perhaps I can manage to get one in your hands.
sgebhart
Engineering Section Manager
New Business Development
Globe Motors
Unread 11-10-2007, 09:45
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
http://www.banebots.com/c/MP-MISC is a similar globe motor....banebots also has some planetary gearmotors too....if that helps...
pic: please help us please mortals CD47-Bot Robot Showcase 5 25-01-2004 11:03
please help us, pretty please :) archiver 2001 0 24-06-2002 03:13
Help! Need a Globe Motor Dodd Motors 0 24-07-2001 11:57
