Go to Post Work hard. Then work even harder. Work until there is nothing left to work on, then work more. - RoboChair [more]
Unread 01-08-2007, 22:52
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
2007 camera kit
We did not have an opportunity to learn how to use the camera kit or autonomous made during this season's competition and would like to get acquainted with it during the off season to better prepare ourselves for next season...
Can anyone tell me the best way to get started with experimenting with this camera kit, what utilities and code is available, and what all is needed (which parts i.e. the RC, the back up battery, etc) to make something functional?
Please include any helpful links...
Also, any helpful suggestions are greatly appreciated...
thank you!
Unread 01-08-2007, 23:26
in between teams
AKA: Luke Van Oort
Re: 2007 camera kit
At the very least, you'll need the control system (RC, etc) along with 12 volt (main battery) and 7.2 volt (backup battery) power supplies for the RC. You'll also need two PWM cables for the camera power and serial data. If you want to use a pan/tilt assembly, clearly you'll need that.
As for code, I believe EasyC comes with code for the camera, but I don't know anything else about it. If you feel like using MPLAB, the code of choice will be Kevin Watson's from http://kevin.org/frc. LabVIEW can be used for calibrating the camera (this shouldn't be necessary, esp if you're just practicing), and there is also a Java applet floating around that does the same thing, but without LabVIEW. Also, if you use K. Watson's "Bells & Whistles" camera code, it has a menu interface that lets you change calibration settings on the fly.
Team 1219: 2009 - Mentor
Unread 02-08-2007, 15:13
LVfan LVfan is offline
LVfan is an unknown quantity at this point
Re: 2007 camera kit
I agree LabVIEW provides a bunch of example programs with their drivers. So its real easy to find one thats similar to your application.
Check out VI Roadshow
Unread 02-08-2007, 15:19
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: 2007 camera kit
In easyC if you open the Projects\Test Code\GDCamera_FRC there is some code.
Also in the Getting Started Section of the Help file there is an advanced project using the camera to "AIM" the robot.
You will need Labview or the CMUGUI to focus your camera as well.
2007 Pneumatics Kit Commander07 Pneumatics 2 17-01-2007 17:09
2007 Kit Conor Ryan Kit & Additional Hardware 69 13-01-2007 12:47
2007 Kit Transmission Brandon Holley Rumor Mill 1 06-01-2007 01:40
Live video with Kit Camera BobcatProgramer Electrical 10 11-01-2005 10:43
