Go to Post (psst... what's the difference between a geek and a nerd?) - sonicbhoc [more]
Unread 15-07-2007, 01:03
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: HomeMade Motor Controllers
Originally Posted by Adam Y. View Post
Also Power MOSFETs are different from regular MOSFETs because there is a diode included . If you look at a circuit symbol for a power MOSFET you will see that diode include.
I'm sure that power MOSFETs do have some differences in construction, but that diode is in all MOSFETs; it's part of the way they're built. This diode is called a parasitic because it exists, but isn't there intentionally. Attached is a drawing of a MOSFET with the parasitic diode in red. Note that the diode only exists when the source and body are connected (as it usually is).
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 02-08-2007, 11:08
SteveJanesch SteveJanesch is offline
hopes he has enough oomph
FRC #1533 (Triple Strange)
SteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to behold
Regarding the original post...
Since you mentioned you are more into microcontrollers now, are you looking to build a full-power Victor equivalent, or maybe a smaller version of some kind of pulse-width modulated motor controller for learning and experimentation? There's some magic going on inside a Victor which converts the 1 to 2 ms pulse into the H-bridge drive, which you can skip if you just want to build an H-bridge and drive it straight out of the microcontroller - more accurately, you can pull that bit into the micro-c and play with it. Instead of ganging up power transistors to get to 50 amp current capability, you can start out with a single transistor in each leg and a smaller motor or lower voltage so you go through less cash replacing blown-up parts.
Assuming, that is, that you're still thinking about building this thing...
- Steve Janesch
Unread 06-08-2007, 13:45
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Originally Posted by John Gutmann View Post
so a MOSFET is like the same thing but only, i guess you would say safer?
The main difference between your PNP/NPN transistors and P-/N-Channel (MOS)FETs is that standard transistor are "voltage" effect while Field Effect Transistos are more of "current" effect devices.
FET devices function much like variable resistors... their spreading resistance allows them to evenly share currents unlike transistors which, when paralleled, tend to put much more (or all) of the current on a single device while the others sit idle. A FET, since you can think of paralleling FETS like paralleling resistors of equal value, transmits curret equally between all of the devices in parallel.
One disadvantage of FETs is that they have strange drive characteristics... they are difficult to turn on and off. Thankfully FETs have become much more civilized and inideof most FETs many of the suppression diodes that were once external are now internal... (i suggest IR for FETs, they make the most friendly ones).
IR(InternationalRectifier) also makes some drive ICs which can handle driving your gates on and off for you, saving some circuit knowledge.
Also, using a PIC to drive your circuit helps as well. Many 16/18 series PICmicros incorporate ECCP peripherals which can directly drive (in hardware) the four lines for a full H-bridge.
If you want more detail... just let me know. Hope that answers some ?'s.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 06-08-2007, 14:52
-q
Alex,
Bipolar transistors are current controlled devices while FET are voltage controlled. I think of the FET as having an insulated gate so no current can flow in a FET. Another reminder is a bipolar transistor must have current flowing through a resistor to bias the base on and cause collector current to flow. FETs do function more like a variable resistance but they are easier to parallel becuase of the very low impedances involved. Both transistors and FETs are best paralleled using a small series resistance in series with one of the output elements to balance the currents in each device. As sciguy Phil, pointed out earlier, the construction technique of power MOSFETs (HEXFETS) causes the diode to be a natural (and usable) byproduct of production.
Unread 06-08-2007, 18:06
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
I asked the questions 2 years ago............But thanks. Even though I have learned the answer in college by now.
-John
homemade speed controlllers (for school project) Denman Electrical 26 18-04-2005 11:07
Homemade Robotics Clothes Jill1022 General Forum 9 28-03-2005 14:57
Globe Motor archiver 2000 4 24-06-2002 00:15
