Go to Post Some clever fellow a few years back made a little scooter based on this principal and made so much on the idea he can afford the finest denim in the land. - phrontist [more]
Go Back   Chief Delphi > Technical > CAD
Unread 02-08-2007, 21:44
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Working from Drawings: A Challenge
I thought this might be a fun thing to try. My work of late requires that I produce part drawings that are given to the vendors that produce our parts and, since 488 uses a nearly paperless process during the season, my skills are a bit rusty.
That said, I thought it might be fun for y'all to learn to read drawings and model parts based on them while giving me a great opportunity to learn where and how I can be more explicit so the parts come back from the vendors built correctly. So, I guess the idea here is that I'll attach drawings to this thread every now and again and, if you're interested, I'd like for you to create a model based only on that drawing.
Sounds fun? Maybe only if you're a giant dork, but I'm a pretty giant dork, so.
Round One: 18GA Steel sheet metal part.
ID:	5653  Click image for larger version
--Madison--
...down at the Ozdust!
Unread 02-08-2007, 22:26
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Working from Drawings: A Challenge
Good idea, it'll help ME get some practice using inventor. That'll take a while though...
Spoiler for a clarification of what I am seeing:
I used to think I was fairly competent at this, but I have a question: You spec out in the flat pattern that the bottom 'flange' is 2.21 wide, but the finished bent flange is dimensioned at 2.25. I know I'll feel foolish in a moment, but how do I bend up a 2.25 flange from 2.21 of material? [EDIT] Never mind, I see it now, up top you allow 0.05 for material thickness, well on the bottom you lose 0.01 for the 'bump' so 2.21 +0.05 - 0.01 = 2.25. Toldja I'd feel foolish.[/EDIT]
As far as that whole area, what I think I see is just a 'bump' in the flange, right? That is, the flange is bent up 90 degrees, after 1.25 it gets bent 'down' (away from the viewer's eyes into the page) 44 degrees, then bent back up 44 degrees (net change zero). The drawing of the bent part seems to show it bending up then down though, however that can be a trick of the downloaded image resolution and the interference with the dimension lines.
Don't look at the spoiler if you're going to model this, better you interpret it your way, not mine.
Don
Unread 02-08-2007, 22:38
Madison's Avatar
FRC #0488 (Xbot)
I added a second attachment to the original post that contains a larger look at the end view. I'd have just put the PDF up, but it contains a bit too much information about what this is and who it belongs to
--Madison--
Unread 03-08-2007, 00:19
Pnakovich's Avatar
Pnakovich Pnakovich is offline
AKA: Paul Pnakovich
FRC #0612 (Chantilly Robotics)
Pnakovich has a spectacular aura aboutPnakovich has a spectacular aura about
Send a message via AIM to Pnakovich
is this metric or english?
Unread 03-08-2007, 00:50
Elgin Clock's Avatar
FRC #0237 (Black Magic)
If it has decimal points in the numbers, then in my experience 90% of the time it's English (or imperial) but that's a good question none the less.
That said, the sheet-metal feature in Solidworks is kinda irritating when you first learn it, (my bends always ended up going in the opposite direction at first) but things like this can be cranked out in no time with some practice. It's actually really cool, the K factor determines what your true radius willl be depending on your final desired angle of the material and the material type.
Good stuff, although to cheat (not that I would ever do that in Solidworks ) I would just extrude the profile and call it a day.. lol
Unread 03-08-2007, 11:08
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
...I thought too soon when I said it would be neat if somebody would post some CAD challenges... Time to get started!
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 03-08-2007, 11:31
Madison's Avatar
FRC #0488 (Xbot)
English. The title block would explicitly mention this, but again, I can't show that
I'm pretty good with the sheet metal features, especially since you can usually just extrude a profile of the finished part and let Solidworks backtrack and figure out what sorts of bends are needed to get there. I have to use the sheet metal features since the vendors like to have the pattern drawings and it's the easiest way, by far, to get them -- though I've seen work by some other folks to get the patterns out that borders between genius and insanity.
--Madison--
Unread 03-08-2007, 12:48
Amir's Avatar
Amir Amir is offline
FRC #1717 (dpengineering)
Amir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to beholdAmir is a splendid one to behold
If your bend radius in not critical then it is probably better to specify “Use Minimum Bend Radius.” Usually, with sheet metal, the goal is to get as close to 90 degrees as possible. If you specify the minimum, then the sheet metal fabricator will use the tooling set-up to achieve a bend that is as close to 90 degrees as possible without overstressing the material.
If you specify a specific bend radius then the sheet metal fabricator should technically try to hit that radius within your specified tolerances. If you have a close working relationship with your fabricator then they will either know what you are trying to do and just use the minimum or they will call you to confirm. If you just send it out to some faceless shop then they may use your specified radius and this could potentially cost more money.
Using the K factor can be helpful from an engineering design perspective so that you know which bend radius is possible, but putting this radius on your drawing is generally not necessary or advisable.
Hope this helps,
Amir
Unread 03-08-2007, 12:49
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
A comment on the holes...
I count 8, the description calls out 7 places. I'll admit that I'm not up to date on dimensioning drawings, is this now read "this hole gets this dimension, now look for 7 others and do the same?" Or is the other hole listed somewhere else and is different for error-proofing?
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 03-08-2007, 13:30
Madison's Avatar
FRC #0488 (Xbot)
Good catch. I added a hole to the model after I first dimensioned the drawing and failed to update the note.
--Madison--
Unread 03-08-2007, 14:34
DonRotolo's Avatar
Back to humble
FRC #0832
OK, now I'm either genius or insane. (Likely the latter)
The bottom 90 bend is "up", the next bend (44) is "down" and the last us "up" again.
But the side view shows these as Up, Up, Down. (CCW, CCW, CW)
Can you help me understand what I am missing here?
Don
Unread 03-08-2007, 15:43
By Jove, I think you're right! That is how it looks!
Cynette
Unread 03-08-2007, 23:43
Pnakovich's Avatar
AKA: Paul Pnakovich
so which is supposed to be followed up, up, down or up, down, up
Unread 04-08-2007, 14:31
DonRotolo's Avatar
Back to humble
FRC #0832
Trust the darwing more than the words. If this was the real world, the guy trying to fabricate a sample, if he couldn't clarify with the designer, wouold use the drawing. Up Up Down until Madison clarifies.
Don
Drawings Charger_07 General Forum 1 09-01-2007 01:37
Goal Drawings Mr Pirozzo OCCRA 3 24-09-2003 17:26
Drawings Mike Martus OCCRA 1 23-09-2003 12:00
Drawings of Boxes Scorpion515 General Forum 1 07-01-2003 21:22
Inventor drawings of parts from kit patrickrd Inventor 1 11-01-2002 14:16
