Re: Interactive DashBoard
It would be nice if this code could be modified to also work with the vex system. That will give a wider user base to develop the features of an interactive dashboard. Hopefully soon we will have a common serial interface to control the FRC RC with a any type of programming language. Overall, great potential !
That really wouldnt be that hard to do, we just need to make a standard protocal. Then you can control it through a program running on your computer or you could add a seperate board running, say java that would communicate with the RC over the serial port
zor!
This looks rockin'!! I can't wait to try it out. This sounds like a 74-hour-marathon-programmer's dream app! Keep up the good work! Jacob |
I've successfully used Kevin's Serial, Camera, and ADC code on the Vex platform.
Since the processors used in the pre-2006 FRC RC is the same as the Vex controller, following Kevin's instructions to run his code on the old or EDU controllers will work for Vex. The only difference is that you need to use the Vex library, which is in the vex "starter code" available here. EDIT: The instructions I refer to are in the readmes for each of Kevin's projects. |
If you have gotten the serial port code to work, then all you have to do is include the DashBoard.c/h and setup the user_routines.c similar to the sample code(or follow the DashBoard_readme.doc instructions)...maybe get rid of the camera stuff...Does anyone use the camera with the VEX? |
#7
I've used the camera without any issues, there are porting instructions for that code as well. |
#8
To continue progress, which one should I continue working on right now:
#9
Thanks everyone for your support and enthusiasm.
Maybe it's because of the off season or summer, but not too many people seem interested. Is there something missing, or is it too hard to implement? If someone can give me some pointers or ideas, I would be very thankful. Thanks in advance. Lohit |
#10
i believe it's the off season.
We ar currently working on the mechanical issues on our bot, but we will soon need the programming. I'll be sure to show our lead programmer your software, it looks great. I can also promise to give you feedback once i have it. It will take a week or 2 though =] |
#11
This program looks great!
Too bad team 808 is out of first for good... but we aren't giving up. We are doing a program called the national robotics challenge and entering a robot for a grand total of 30 some dollars. With none of the limitations of FIRST, we are actually going to try to send sensor output to a laptop and do all the long calculations there, but we're having problems doing this. Would you mind answering a few questions? Was this program created in Visual Basic using the .net framework? If it was, can you provide some source code or provide an example on how to read data into the visual basic program? - every time I try to read input from the serial port in my test program from the RC, I get question marks. I'm using Kevin's serial port code to send data to the computer. Our team membership currently numbers four and we are all trying to learn as much as we can. Thanks for your time. Dan - former team 808 |
#12
If you want to see how to use .net serial comm to communicate with the RC have a look at seanwitte's dashboard viewer. Its written in C#, but the implementation is very similar. If you want help with .net serial comm, or .net in general feel free to PM me. |
#13
Make sure your baud rate on the program matches the RC's, which is 115200. Trying to set up a communication protocol between the RC and the computer was probably one of the most time consuming parts of the whole project. I actually used a software called Free Serial Port Monitor to see every byte that entered and left the serial port. This helps you see the difference between what you believe it is sending and what it is actually sending. The software has some major bugs: feeding it too much data crashes it(ex. reading the bytes while flashing the RC will crash it). It was not that hard to freeze it but it was a valuable asset to my project. If it does start freezing go into Task Manager->Processes->Select Device Monitor->End Process. Don't try to do it by closing or ending task because it just hangs for a while. You might be able to find some better software but this was the only FREE one that I could find. http://www.freedownloadscenter.com/P...t_Monitor.html Go to the bottom. Just because you are getting a question mark doesn't mean you are not getting garbage data. ? = 63 in decimal...try reading byte instead of char from the serial port. Could you elaborate a little bit more on your goal or setup? Lohit Last edited by 6600gt : 10-08-2007 at 03:35. |
#14
Wow. Thanks for the quick replies.
EHaskins - thank you for showing me that white paper. I thought I had done a thorough search on serial ports in the white papers section, but it never occurred to me to search for another dashboard viewer. ![]() 6600gt - thank you for the program. It seems like it would help me a lot. It would be great to see what was truly being sent. To elaborate on what I'm doing: our robot is going to be a heavyweight sumo robot - 150 lbs fully autonomous. We hope to take all our sensor readings - both digital and analog - and send them to a laptop through a wireless serial transmitter. The laptop should then read the information and perform heavy math to find where the robot and the opponent are on the field. The laptop will then send pwm outputs back to the robot (within one program loop - would that be possible?). Thanks for the suggestion - I'm going to try reading bytes whenever I get the chance to. Once again, thanks - these tips are great Dan - 808 |
#15
It is possible if you can get the RC to transmit and the PC to process and transmit back all in 26.2ms! It is probably possible but the whole system will probably lag behind 1 or 2 program loops. Since you send the sensor values in the current loop and receive processed data in the next one.
| Interactive Debugger/Monitor | duane | Programming | 10 | 11-10-2006 23:26 |
| Labview Dashboard and updated IFI dashboard spec | Joe Ross | LabView and Data Acquisition | 1 | 04-04-2006 02:04 |
| FIRST Interactive Rural SupporT | coreyk | FIRST Interactive Rural SupporT | 1 | 12-11-2003 10:31 |
| Interactive Map - Out of Date | Don Knight | General Forum | 0 | 19-09-2002 17:54 |
| interactive strategy | piconysm | Rules/Strategy | 5 | 11-01-2002 08:47 |
